08-25-2010, 09:53 PM | #23 |
Viper Driver
36
Rep 1,311
shipping costs would be quite high indeed. i do agree concerning the amber reflectors on the front bumper. they stand out a lot and just look out of place. the rear lighted reflectors aren't actually half bad, but i'm getting rid of them as well as i absolutely adore the clean, constant finish.
08-25-2010, 10:25 PM | #24 |
Rep 1,143
Since the rear reflectors are functional and the red matches the tail lights, they don't bother me too much. (But if somehow a Euro rear bumper somehow landed on my doorstep, I would probably install it!)
09-03-2010, 07:29 PM | #25 | |
Rep 10
Yours is the only post I found addressing the bumper-to-fender brackets (51117165179/180). The jpeg below illustrates my problem. Is this similar damage to what you had experienced? I took it to my BMW dealer who couldn't make head or tail of it and suggested a body shop. My guess is that the left and right bracket supports are cracked and their replacement would do the job. I am, however, at a loss to imagine how they'd attach. Does the bumper end simply 'click' into the brackets? Any thoughts would be appreciated. |
09-03-2010, 07:50 PM | #26 | |
Rep 11,669
There is also a 2 part urethane bumper filler available.
09-03-2010, 10:41 PM | #28 | |
Rep 421
09-03-2010, 11:46 PM | #29 | |
Rep 1,143
In your case, it almost looks like the 3 plastic tabs sticking up from the bumper have not been pressed all the way in. Try pushing it in while holding the fender with your other hand -- the tabs should "catch" into the correponding spots at the bottom of the plastic bracket. It's possible that the bracket has a crack behind the bumper which is causing it to flex, making it impossible for the tabs to be pushed completely in. |
09-03-2010, 11:57 PM | #30 | |
Rep 10
Thanks
I'm sure I'll figure it out when I get the bumper and bracket off (which appears to be a somewhat trivial exercise). Perhaps I could solicit the name of a reliable online parts retailer for the two brackets? Thanks again. This forum is a great resource. |
09-04-2010, 12:03 AM | #31 | |
Rep 1,143
09-04-2010, 12:04 AM | #32 | |
Rep 10
I've tried the method you suggest with no luck. Many thanks for the response and helpfulness. |
09-04-2010, 12:31 AM | #33 |
Rep 2,877
Looks like these two support pieces (circled in the attached picture) may have broken off, which is the reason why the 2 tabs can't stay in the "catch". I did replaced that piece a few weeks ago on my coupe, without completely removing the bumper...what a pain in the butt it was in breaking away the old piece. Just have to be very patient with it. I think all of us will become experts at replacing the front bumper trim pieces sooner or later
09-04-2010, 09:31 AM | #34 |
Rep 10
What daylight reveals...
Well, I looked at this in the morning light. I took out the top wheel well rivet and observed the bracket as I moved the bumper end up and down. It has been my understanding that the bracket is rigidly attached to the fender lip and should remain stationary with bumper movement, but the bracket moves with the bumper, which suggests to me that the bracket has a flexible crack along the rail line (hence the "wavy" rail in my jpeg).
Does this sound reasonable? Many thanks. |
09-04-2010, 01:00 PM | #35 |
Rep 10
The Journey Forward...
Well, my BMW dealer actually had the brackets this morning, so I bought them. I'll take a few deep breaths and perhaps a few days before I tackle it.
I'll eventually post picks of the presumably damaged brackets so that others might see what can occur with these things. |
09-04-2010, 03:30 PM | #36 |
Rep 10
Hose Routing
Okay. Bit the bullet and did it. Detailed explanation later, but the new support brackets are in. Now I'm just wondering about the routing of the headlamp washer hose around the front bumper, since I'm ready to slide the bumper on and snap the ends into place.
Many thanks. |
09-04-2010, 04:36 PM | #37 | |
Rep 1,143
I had half a mind to remove the nozzles since I actually unplugged the electrical connection for them. After verifying that they worked, I had no interest in using them. While they might clean the headlights okay (though I've never had an occasion where the headlights are dirty enough to warrant cleaning), it gets your hood all dirty, which seems counterproductive. |
09-04-2010, 04:52 PM | #38 |
Rep 10
Thank you
Thanks. I put the hose back in the clips and routed it around the arc above the lower oil cooler grille. It's not going anywhere.
Anyway, the bumper looks great, the new clip rails are not perfectly straight between the bumper and the fender, but that seems to be normal from what I've seen (they dip a little towards the front, probably because there's not a connecting tang in that area, just a post). In any event, it looks really good — certainly good enough to not bug me anymore. I'll note my experiences with this later. Beer comes first. Many thanks again for everyone's help. |
09-04-2010, 06:47 PM | #39 |
Rep 10
One thing to add...
According to others who've done this, the difficult part of this operation seems to be getting the old brackets off. What I did was gently slide an oiled box-cutter blade between the fender and the bracket rail. Tap the protruding edge of the blade with a hammer a couple of times and the tabs holding the bracket to the fender pop right off (careful with that paint, Eugene).
Hope this helps others contemplating the work. |
09-04-2010, 10:30 PM | #40 | |
Rep 1,143
09-05-2010, 12:56 PM | #41 |
Rep 10
One more thing...
I think it also bears mentioning that the tab (marked "3" in XMetal's graphic above) needs to be behind the metal plate hanging from the fender. I Nearly missed this when installing. So the deal is to slide the bracket up into the fender with that tab engaging behind the plate, rather than angling the bracket into place.
09-05-2010, 01:30 PM | #42 |
Rep 421
09-05-2010, 01:45 PM | #43 | |
Rep 1,143
08-23-2012, 08:06 PM | #44 |
Rep 46
Drives: 2007 M Coupe
dekaliber, where did you order the bumper from? I cant seem to find it for that price. Thanks.
