09-11-2016, 07:36 AM | #1 |
Rep 53
Make you e85 back to 18 years old
Before: 1.The acceleration of starting was weak for 3 years. 2.A subtle stutter was noticeable while reverse parking. I put cleaning agent into every cylinder from spark plug mouth and then use air pump to clean it two week ago. Now my e85 is back to 18 again. It feels so good that It make me lost all interest in e89.
Step1:Hot engine after high speed driving for a period of time and then unscrew 6 spark plugs. Step2:The cleaning agent is divided into six servings poured into six cylinder respectively from the spark plug hole in the engine. Step3:Waiting 15 mins. Step4:Use pump pressure booster gun to blow compressed air into cylinder room from the spark plug mounting hole covered with a cotton cloth. You'd better blow as more direction as possible. The cloth is prevent the cleaning agent come out. Step5:Use pump pressure booster gun to blow cylinder room directly without cloth cover. Make sure there are no cleaning agent in it. Step6:Start the car without spark plugs for 3 times. Each time last 3-4 second.(It is very importand!) Step7:Install the spark plugs and starting the car. Idle the engine for 3 minutes and then keep 3000 RPM for 3 minutes until there is no peculiar smell come out from the exhaust pipe. Be careful to not pour the cleaning agent on to the hot engine surface to avoid fire.
http://www.zpost.com/forums/showthread.php?t=928193" border="0" />
09-11-2016, 10:44 AM | #2 |
Rep 2,866
BUT...my car is only 8 years old, why would I want to skip 10 years of enjoyment by jumping straight to 18???
In all seriousness, glad you found an inexpensive way to solve your issue. |
