      07-05-2018, 12:57 PM   #1
CTMP4me
Drives: '08 Z4MC, '71 240Z with S54
Clutch options - experiences with OEM vs. other options
I am due for a new clutch soon and want to hear views and opinions on the options. Engine is on stock internals for now, stock-ish power levels, might go as crazy as CSL cams + 3.5L stroker + head work into 2019 but ultimately staying N/A rather than going SC, so torque capacity isn't a special consideration.
I don't mind stock clutch + dual mass flywheel, heard stories of chatter with lightweight flywheels and springhub clutch combos. I am also considering making the jump to a Tilton carbon-carbon twin disc clutch, provide the adjustments to it need to be made every 5-10K.
Car will see ~75% track mileage but I do want some degree of streetability, which is where the carbon-carbon setup is said to work acceptably.
      07-23-2018, 07:13 AM   #2
Terraphantm
Drives: E46 M3 Coupe
N54 or N62 clutch might be worth looking into since those motors make a decent bit more torque. I know the disc would fit, I’m not sure if the pressure plate bolt pattern is the same
      07-23-2018, 07:49 PM   #3
mainsoda
mainsoda's Avatar
Drives: 2006 BMW Z4M coupe
I have a J&B Performance clutch/ultralight flywheel and it works great, but it rattles with the clutch pedal up in neutral. It's kind of annoying.
      07-24-2018, 03:28 PM   #4
CTMP4me
This is why I started looking at this: https://store.langracing.com/s54-til...nd-clutch-kit/
It's 2x+ the price of other clutch and flywheel packages though, and I haven't seen it used outside of high HP drag builds. I just want an 8K+ RPM S54 that's as revs like a Carrera GT / LFA...
      08-10-2018, 11:28 AM   #5
Arsonism
Arsonism's Avatar
Drives: '08 M Coupe
If it's lang it's worth the money.
I currently have a UUC Kevlar Clutch and Lightweight Flywheel. Although it does rattle like most any other lightweight flywheel on these cars... it has been a blast to drive with.
◙ Shane
