07-14-2016, 10:53 PM | #2 |
Rep 115
07-15-2016, 01:56 AM | #3 |
Rep 869
Did you drive it with the sport button activated? If you did, DON'T! That thing will mess up the clutch fast in combination with the CDV (Clutch Delay Valve) if you do some spirited driving/Auto-X.
LuK is an OEM supplier and they make quality products. |
07-15-2016, 04:32 PM | #5 | |
Rep 143
07-15-2016, 05:48 PM | #6 |
Rep 11,667
There are driveability issues as well.
07-16-2016, 09:51 AM | #8 |
Rep 2,176
07-16-2016, 12:03 PM | #9 |
Rep 2,541
I don't have any suggestions for replacement parts, but you're right, that is very few miles to need a clutch. Do you know the history and driving habits of the previous owner. Have you had a blackstone oil report done? If not I highly recommend it in case the previous owner spent allot of time near redline (they may have since the clutch is spent at 41k) which can prematurely wear out the rod bearings.
07-16-2016, 12:23 PM | #10 |
dances with roads
4714
Rep 4,094
Blackstone report sounds like a good idea to me too. Clutch shot at 41K miles indicates one of two things:
08-04-2016, 04:12 AM | #12 |
Rep 869
Well, the sport button fucks up the throttle response making it too sensitive and that creates a perfect storm for slipping the clutch while doing some spirited driving. The throttle response is awesomely linear without the sport button, don't understand why anyone would want to get rid of that. It doesn't give you anything in an M except for the fucked up throttle response.
08-04-2016, 07:08 AM | #13 | |
Rep 11,667
I can't count the number of times I've heard guys asking "why does this car jack rabbit so badly when starting off?" Often, they are using sport mode.
08-04-2016, 10:36 AM | #14 |
salty cowboys fan
6155
Rep 3,402
This comes to mind lol
Love sport mode btw, will admit it's tough in sandals though
08-04-2016, 12:30 PM | #15 |
Rep 11,667
lol, what a dipshit!
Pretty bad if he can tell the difference between cutch and rubber smoke.
08-05-2016, 02:11 AM | #16 |
636
Rep 3,124
This came to mind for me.
Over 140k miles in sport mode. Clutch is fine. OP's PO must have been PoS.
08-05-2016, 11:14 AM | #17 |
Rep 1,772
Drives: 2007 Z4M Coupe
Amazing! Love hearing stories like this
08-06-2016, 08:53 AM | #18 | |
Rep 911
I run a setup on my Supra and never looked back. In the end, you save hundreds to thousands of dollars for clutch, flywheel and pressure plate vs. going all OEM replacement. You should resurface or replace the flywheel (I believe dual mass flywheels are non-serviceable). TurnerMotorsports option linked above is a good one, also Clutchmasters sells a complete kit for the Z4M.
Andre - 2J into a Z4 Coupe!
