      06-17-2012, 03:17 PM   #23
Kgolf31
Kgolf31's Avatar
460
Drives: 2007 Z4MC, 2012 128i
Originally Posted by kklin View Post
That was my thinking too. I did left sides one day and let it sit on stands and then did right sides the next. So plan your weekend accordingly.
How long does the loctite take to cure?
      06-17-2012, 08:11 PM   #24
3002 tii
3002 tii's Avatar
2285
Originally Posted by gtMc View Post
ok, thanks.
interesting. good thought here on the process. which leads me to ask, is this a reversible mod?
Yes, if anything just like oe bolts, these should be replaced every few years. Hence I plan on getting mine redone sometime this summer.
Follow for latest mods
      06-17-2012, 09:54 PM   #25
kklin
Drives: BMW Z4 M Coupe
Good question - I asked the same...
The kit I got from Vorshlag came with two small resealable tubes of the following, in factory packaging ...
1) Vibra-Tite Anaerobic Threadlocker Permanent Strength RED 13102.
The packaging says "Compare to Loctite 262". The cure specs of Loctite are here - http://tds.loctite.com/tds5/docs/262-EN.pdf
2) HD Industries Copper Anti-Seize 907C
      06-18-2012, 02:11 PM   #26
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
I use a cordless impact wrench, breaker bar, and torque wrench. Do not use a torque wrench to break loose nuts - I did this once long ago and broke the wrench.
If you get an impact wrench, don't bother getting a impact socket. The walls of mine were too thick and did not fit inside my wheel. Just get a Craftsman - if it breaks, you just get a free replacement (I've done this).
damn! more stuff to put on my "I really think I need/want this list"
I don't mind if I break my torque wrench. Its a big Harbor Freight model that caused me to break a spark plug before. I really like the idea of a cordless impact wrench to save time
      06-18-2012, 02:30 PM   #27
kklin
My Milwaukee cordless impact wrench (a Christmas present from my wife) with NiCD is rated at something like 100lb/ft. It's not quite enough to "break" the nuts that are on even though I hand torque them to about 85, thus the extra breaker bar. Don't know if a cordless with a beefier motor/battery would eliminate the need for a breaker bar. If so, don't overtorque.
      06-18-2012, 03:37 PM   #28
Kgolf31
Kgolf31's Avatar
460
I have a craftsman air impact wrench which i used to break nuts loose, then i torque to spec when putting them back on
      08-14-2012, 02:38 AM   #29
ANILE8
ANILE8's Avatar
No_Country
180
Drives: Z4 M Coupé - Carbon Black
This thread just reminded me to get around to doing this simple but effective modification.
      08-14-2012, 08:30 AM   #30
Kgolf31
Kgolf31's Avatar
460
From between when I installed them and now, I must of changed wheels around 5-6 times.
It has cut my time in half (now around 20-30 mins for all 4 wheels...including the time to set-up my air impact), so easy to just throw the wheel on the stud and hub, tighten the first lug and it's centered and ready for the other 4.
      08-14-2012, 10:38 PM   #31
ANILE8
ANILE8's Avatar
No_Country
180
Now if only we had centre lock wheels we could cut that time down to about 20sec per corner.
