04-05-2012, 08:38 AM | #1 |
Rep 30
Help with VT1-450 belt question
Hello guys!
Since we are not allowed to modify our cars here in Sweden and are by law required to go through a inspection once a year, i now need to take my belt of the supercharger unit. Although that might not be enough for me to clear the inspection(it has been reported to work in some cases), i think it might be worth a try so i dont need to remove the whole S/C unit. Since im no mechanic myself, how would the car function without any belt at all/with stock belt? Keep in mind that i need to clear some exhaustvalue tests. Any thoughts? |
04-05-2012, 08:58 AM | #2 | |
Rep 5,329
btw my car passed all smog tests with stage 2 tune..... it'll pass the emissions, trust me!!
04-05-2012, 09:11 AM | #3 |
Rep 30
Sounds good!
I think i'll go with the stock belt, although, how much work is it vs removing the whole unit? Is it a easy task returning to stock belt? Any guidelines? To run the car with stock tune, what do i need to do/purchase then? Since i let the guys in norway install everything for me im pretty clueless regarding this :P Thanks for the answer |
04-05-2012, 09:15 AM | #4 | |
Rep 5,329
Re the stock tune, buy the ess flash tuner and just load it up to your car, they will have the stock z4m file their, you already own it as part of the s/c purchase price.... holy shit this sounds expensive..... i defo wouldnt put myself through this if the law meant i had to do what your doing.... forget that.... still think the best option is to run a cover, i have a friend in norway who;s done just that and passes everytime no problem...
04-05-2012, 11:25 AM | #6 |
Rep 5,329
Dont be so stupid.....
you'd need naked hookers or AT least herion mixed with some sort of crack cocaine......
04-05-2012, 11:35 AM | #7 | |
Rep 30
Could you get your friend to post some pictures here? Would help alot seeing his solution. |
04-05-2012, 12:14 PM | #8 |
Rep 5,329
Hes not on here but ill grab some pics, he made the cover using sheetmetal painted black. Looks verryyy covered. Lol
Mines pretty quiet at idle, is urs noisey??
04-05-2012, 03:19 PM | #9 | |
instagram 997turbotom
279
Rep 7,377
I agree on making a cover for it. Should pass visual inspection. Its also quiet enough for a normal tech to think its a stock sounding engine. As for the emmisions, my car does not pass, and ESS said they were not designed to pass
04-06-2012, 03:45 AM | #10 | |
Rep 5,329
i have the uk pass sheet for ALL emissions tests :-) shall i post an iphone pic of this sheet?? if the stock cats are in place their is absolutely NO reason why this cant cant pass any tests a stock car would.... bare in mind during tests this car is making 0 boost....
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com Last edited by Beedub; 04-06-2012 at 04:08 AM.. |
04-08-2012, 01:00 AM | #12 | |
Rep 5,329
Lol.....
