11-18-2010, 02:35 AM | #23 |
Rep 91
11-18-2010, 07:11 AM | #24 | |
Rep 632
Set systems straight - clearly
'06 and prior, pressure is monitored indirectly by the car monitoring wheel rotation. As a tire loses air pressure the rotation of the affected wheel is altered, I think by having a slower rotation relative to the other wheels but I'm not entirely sure how it works - regardless, the car can sense this relative change in a deflating wheel's rotation and the indicator will come on. My '04 E46 M3 had this system. '07 and up, pressure is monitored directly by a device attached to the valve stem inside the tire. The entire system is different - '07 sensors don't work with the prior systems, and wheels without sensors will cause the indicator to come on in '07 and up cars. With the pre-'07 system, the tire has to deflate more than with the '07 and up system, relatively speaking, before the indicator light is set off because of the way the wheels are monitored - indirectly versus directly. This is the main reason for the change, to my knowledge. I think I have this right - if not, please correct me. Shipkiller is the man: http://www.zpost.com/forums/showthread.php?t=456173 http://www.zpost.com/forums/showthread.php?t=456170
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=| Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo) RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint Last edited by onebluemcm; 11-18-2010 at 09:39 PM.. |
11-18-2010, 07:31 PM | #25 |
Rep 725
^I think that would be faster rotation as the diameter of the tire is reduced with less air.
The rest of what you're saying seems to make sense but I also don't know for sure. |
11-18-2010, 09:33 PM | #26 |
Rep 632
Yeah, that could be, but my thought was that as it loses pressure, there might be more rolling resistance which might slow it down relative to the others. Somehow, it must work, but I'm glad to have the newer TPMS....
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=| Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo) RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint |
11-19-2010, 04:07 AM | #29 | |
Rep 91
So this will save me some money as I have a 06 Roadster M. This is a good thing |
11-19-2010, 04:25 PM | #30 |
M = Midlife Crisis
65
Rep 2,006
No
2006 Z4MC - #LL93158
