      08-13-2010, 03:28 PM   #1
brandobot
Drives: 06 Z4M
Engine noise at cold start, and driving at lower RPMS
At cold starts, I get a lot of chattering like something is loose. The noise goes away once it warms up. It sounds like it's coming from the oil filter housing or somewhere in that vicinity. From a complete stop, it'll make the noise when I start to get it rolling and will usually go away as soon as it starts rolling. If i'm in low RPMs in second gear and I step on the gas a little, you can also hear it.
The car was perfectly fine until I changed the oil, oil filter, differentail fluid, and transmission fluid. The air filter was also replaced but I switched it back to stock and the noise is still there.
      08-13-2010, 04:34 PM   #2
Z4-VILLA
Afghanistan
111
Drives: Z4M Hardtop Roadster
http://www.drvanos.com/
      08-13-2010, 04:55 PM   #3
brandobot
Drives: 06 Z4M
Does the vanos only make noises on lower rpms or throughout the whole power band?
      08-13-2010, 06:17 PM   #4
Z4-VILLA
Afghanistan
111
usually low rpm.....mileage?
      08-13-2010, 07:01 PM   #5
brandobot
Drives: 06 Z4M
60k miles. It happens at cold start for about 20 seconds, then disappears. If i'm in second gear at 1000 rpm, and i step on the gas, I can hear it for about 1-2 seconds very quietly. After that, it's completely gone.
      08-13-2010, 08:41 PM   #6
brandobot
Drives: 06 Z4M
      08-14-2010, 02:53 AM   #7
Z4-VILLA
Afghanistan
111
thats a vanos issue also get new pulleys, = fixed.
