03-21-2014, 12:24 AM | #1 |
Rep 2,866
S54 stumbling at idle
Anyone have this issue with their S54 engine where it would stumble momentarily (for about 1/2 a second or so) where the engine would drop to about 500rpm during idling? The engine never died/cut-out...just stumbled. This has happened to me a few times in the last several months...usually while waiting at a light. Any clue what may have caused this? Thanks.
03-21-2014, 01:29 AM | #2 |
Rep 516
I have this issue, especially when im running on low fuel (light on). I was told that it could be my coils going out. Or simply running on low fuel
03-21-2014, 07:51 AM | #3 | |
Rep 1,772
Drives: 2007 Z4M Coupe
03-21-2014, 07:59 AM | #4 |
Rep 1,031
I had this happen once or twice during the summer in the first year I bought the car. I picked up a tune and it didn't do it the following year. Never figured out what it could be as it only happened those two times on really hot and humid days.
03-21-2014, 08:31 AM | #5 |
Rep 452
This has happened on the M and it also happened on another BMW car I once owned. As Mirko stated, it has not happened since receiving a tune. Did not bother me enough to do anything about.
03-21-2014, 08:50 AM | #6 |
Rep 1,107
I get it once every couple of months too. I figured it's just like my passenger window that sometimes doesn't auto up correctly. Shit happens..move on. That said, I do keep a spare new coil in the trunk.
03-21-2014, 09:47 AM | #7 |
Rep 2,866
Appreciates the input. Seems like there's a bug in BMW's tune, then. I only had something similar to this happened once in the 10+ years that I have owned the X5, but the M appears to do it every now and then...may be even once per month or so.
03-21-2014, 10:16 AM | #8 |
Rep 1,990
Yep- mine does it occasionally as well. It has also started running slightly rough when not used for a while(not stumbling, just feel more vibration in the cabin than usual for the first run after it sits for a couple of weeks.) After a decent run this goes away.
03-21-2014, 10:18 AM | #9 |
Rep 219
Drives: 2007 BMW Z4 M Coupe
Garage List 2000 Volve S70 se [0.00]
2000 Triumph Dayton ... [0.00] 2007 Husqvarna TE250 [0.00] 2002 Ducati Monster ... [0.00] 2007 BMW [0.00] |
I was having that issue frequently when I was filling up at a local 76 advertising 100% Ethanol free (which was why I was there).
All but went away when I switched to a Shell station nearby. It now maybe happens once every month or two. I chalked it up to bad fuel... Or at least fuel that burned differently that the ECU/ignition expected. |
03-21-2014, 11:48 AM | #10 |
1821
Rep 5,337
My Hyundai does that when the AC compressor kicks in.
03-21-2014, 01:33 PM | #12 | |
Rep 2,866
I usually drive without AC...so it shouldn't be that. |
03-25-2014, 02:32 AM | #13 |
Rep 924
It happens to all of us. "Normal" as far as BMW is concerned.
When it happens, I look at my passenger and... .... wait for it... .... "because racecar." .... when I'm really thinking ()
03-25-2014, 12:59 PM | #14 |
Rep 299
Mine does that right after I start the car.. It will crank, run for about a second, then rpms will dip down. Sometimes it does stall, but once it's going it runs fine. If I hold the throttle open about 1/4 when I crank it, it doesn't do it at all.
- Wes
2007 BMW M Coupe 2016 VW GTI |
03-29-2014, 11:22 AM | #16 |
Rep 219
It's a glitch.
I sincerely believe it's something in the ECU related to fuel delivery. I know it's totally speculative... but I had a bad run for a few months where it was BAD. Every day. Very frequently. Cold, hot, whatever. It would dip so bad once or twice a week that the car would DIE. The only thing I changed was fuel and it all but went away. I still notice it slightly: a dip in RPM maybe once a month. But nothing at all like it was. |
03-29-2014, 11:49 AM | #17 |
Rep 711
I think it's common when the engine gets starved for (cold)air and the tune needs to adapt. A good example is coming off the freeway and getting stuck sitting at a red light.
With the stock tune, I could fairly consistently get it to stumble this way. Just for a second and it would recover.
|Evolve Airbox - Euro Headers - Strömung Exhaust - H&R Coils - 19" BBS CH-R| |
03-29-2014, 05:08 PM | #18 |
Rep 820
Drives: 2007 Z4MR silver grey
Same here, mine does it randomly as well..... can't seem to tie it to a type of fuel, engine temp, nor a weather temperature.
03-29-2014, 05:19 PM | #19 |
701
03-31-2014, 01:05 PM | #20 |
Rep 420
mine has stalled a few times. Once I was having such a bad day and it stalled on me and I'd had it. I floored the accelerator and then turned the ignition and it roared straight to redline from Off. Dumb of me. The car smelled like burning shit for a little while after that.
05-08-2014, 08:19 AM | #21 |
Enthusiast
16
Rep 245
I had an odd occurrence the other night - adjusting the headlights with the car running - it just stalled. No dip in RPM, just quit. Strangely enough, its the only time the car has stalled other than when I had a TPS fail. Started right back up, no issues.
2016 550i M-Sport
2008 328i M-Sport (Sold) 2007 Z4M Roadster (Sold) |
05-08-2014, 01:28 PM | #22 |
Rep 46
