06-20-2013, 09:34 PM | #1 |
Rep 321
Right side engine bolts
Greetings,
Since finding out about ZPOST a few years ago I have appreciated the wealth of knowledge that is shared from the members. I had read about the problem of the right side engine bolts becoming loose or breaking. I started keeping a file of information that I could refer to when the day came that I would own a Z4M roadster. I picked one up last October and put it in storage until this past May. I took my car into the dealership today to have them check the engine bolts, strut bar bolts, and the sway bar bushing bolts. I took in a copy of the BMW service bulletin posted by Ron Stygar (thank you Sir!) as proof of a potential problem. The mechanic called me into the shop and said I was "lucky I had him check". He found the front two bolts completely off. Many thanks to those members that share their knowledge and expertise!! BTW... I ordered the 10.9 BMW MotorSport replacement bolts. When I take my car back in for Inspection I, I will have them replace the old bolts with 10.9's. Many thanks guys!!! |
06-21-2013, 01:47 AM | #3 |
635
Rep 3,124
I replaced mine with MotorSport replacement bolts when I was under there replacing my leaking Constant Pressure Valve.
Since one has to disassemble the same things to get to each, when you take it in next you may want to get ahead of the game and have them replace the CPV as well. Mine started leaking just shy of 7 years old and 78k miles. The part is cheap, and since they're already doing most of the labor, bundle and save! I still have to replace my left side bolts when I get a reason to pull the intake manifold. |
06-21-2013, 01:03 PM | #4 |
Rep 1,663
Nord-lock them while you're there! That way you're guaranteed they'll never back out again. See my mod thread for part numbers.
06-21-2013, 09:39 PM | #5 |
Rep 1,106
No need to replace the entire CPV, just replace the brittle O-Ring that is leaking.
http://m3forum.net/m3forum/showthread.php?t=369406 |
06-21-2013, 10:52 PM | #6 |
635
Rep 3,124
I did use his replacement O-rings, but as for the valve, it's cheap and it does have a spring in it that's had a good run after 7 years and nearly 80k miles.
