      05-22-2013, 06:02 AM   #1
jaffar
Drives: 2006 Z4 2.5si
how does one properly drive an automatic
Hi all
I know, it seems a stupid question, please bear with me.
It's my first automatic car. Simple question - while in busy traffic and having to stop every few meters, what is best ?
- always leave it in D
or
- put it in N
Which is best for my gearbox life ?
I feel that the gearbox is trying to push the car while in D and braking, so this seems not healthy.
Thanks,
Dan
      05-22-2013, 07:00 AM   #2
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Keep it in drive.
      05-22-2013, 10:41 AM   #3
speddmn
Drives: 05 3.0i
Originally Posted by pokeybritches View Post
Keep it in drive.
this.
      05-22-2013, 10:55 AM   #4
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6158
Drives: ‘06 Z4MR, ‘20 X7, ‘22 M4x
Automatic tranny has a part called a torque converter which is a fluid clutch. This is the part that allows you to stop while in drive with the engine running, and it's completely normal operation. Leave it in D.
      05-23-2013, 09:11 PM   #5
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
Here's what you should NOT do: while driving about 20mph, switch to N, rev to 5000rpm, and then quickly switch to D
      05-23-2013, 11:35 PM   #6
mgwatson48
mgwatson48's Avatar
Drives: 2008 E86 M
How did you get your license?
SOLD: 2008 M Coupe
      05-24-2013, 12:07 AM   #7
seank
enthusiast
seank's Avatar
48
You might say that, but I would say that most just leave the car in over-drive, which tells me they don't know how to drive an automatic.
      05-24-2013, 12:39 PM   #8
davesz4mc
Drives: 2007 z4mc
Overdrive is just the final drive gear, The locking torque converter then engages the locking clutch for increased economy.
Alot of trucks come with a function to turn that locking off when towing so as not to damage anything and keep up engine speed.
When on the highway and you get on the gas to accelerate you can feel it unluck even though it may not downshift it will "gain" a few RPM as it disengages.
Overdrive is part of drive not a seperate element.
I have driven cars with a "high stall" converter that will still rotate the back tires even when stopped at a stop sign, cars with rear drum brakes.
the brakes keep the transmission from turning when stopped so there is nothing happening/no moving parts at that point. You remain stopped because the energy being transfered by the fluid in the torque converter is less that the force of the breakes holding the car still.
2007 Z4MC, 1" drop H&R Springs, Evolve Tunning, Headers, K&N Filter, RPI scoop, Red top high energy coils, UUC Red Poly mounts (none bolt-through), UUC Lightweight Flywheel with Organic Clutch and a custom exhaust with just one AeroTurbine muffler.
      05-24-2013, 01:30 PM   #9
beta
Drives: 2006 M Roadster
Really? This is not that kind of forum. How about keeping it constructive.
I don't have the faintest idea of how anything about an automatic works and thought it was a reasonable question.
There's always stuff to learn and there's always room for improvement. For example you shouldn't keep your hand on the shifter in a manual, only touch the shifter when you are changing gears.
      05-24-2013, 02:09 PM   #10
mgwatson48
mgwatson48's Avatar
Drives: 2008 E86 M
Sorry but when someone is asking how to drive an automatic I lol a bit inside. If it was an SMG then it would be a different story.
SOLD: 2008 M Coupe
      05-25-2013, 09:18 AM   #11
pokeybritches
2006 BMW Z4M  [8.50]
This is true. In older cars at least, resting your hand on the shifter would cause premature wear in the syncros. You should also switch gears by cupping your hand over the top of the shifter.
      05-25-2013, 10:16 AM   #12
norcal_cyclist
Drives: 2006 Z4 3.0si
1999 BMW 323i  [0.00]
Wow that's helpful... what you don't realize that here in the US most cars are autotragics. Elsewhere most are manuals... this is no different than an American not knowing how to drive a stick, most do not. I haven't met anyone in SA that doesn't drive a stick or was taught to drive in one.
I did have a customer who put their car in Manual mode and drive around w/o shifting. They called to complain of the elevated noises from the car on the freeway. I had them come in from Pleasanton to Sacramento. My tech drove the car and said nothing was wrong so I had him go with the customer. She got in, pulled the paddle shifter, driving off never touching it again. Needless to say it stayed in 2nd gear....
