      03-11-2013, 08:09 PM   #23
Shipkiller
Shipkiller's Avatar
Drives: Me
Just to make sure we are talking about the same thing:
      03-11-2013, 08:15 PM   #24
bignosejim
bignosejim's Avatar
Drives: 2007 IB M Coupe
Looks like he raised the engine though.....
You have to do that to pull the oil pan. Definitely could help with the vanos also.
      03-11-2013, 08:21 PM   #25
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Yup...
I think there must be a mistake on the online price.
      03-11-2013, 08:22 PM   #26
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I found another post that said you have to unfasten a hood release cable bracket, then there is room.
      03-16-2013, 02:03 PM   #27
beta
Drives: 2006 M Roadster
I'm getting ready to order parts. I think in addition to what I posted here I'm missing the 4 copper crush washers that go on either side of the oil lines. In the video he also replaces the banjo bolts.
I'm also considering just getting a static 10Nm click wrench. I don't think there's any other torque needed.
I'm going to need feeler gages, a micrometer and metric wrenches. Please let me know if I need any other tools as my toolkit is pretty sparse.
      03-16-2013, 02:38 PM   #28
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
When you do this, especially if you're going to DIY yourself or with Lon and Chung, please let me know. I'll drive down if I can--it's a good chance for me to learn. I have a good metric set of sockets, extensions, ratchets, and a rather paltry and old set of 6mm - 18mm box wrenches. Unfortunately I don't have a micro-torque wrench (only 20ft lb and up).
I may have missed a post elsewhere, but I expect you're doing the valve adjustment at the same time? I have the shim kit and tool (pretty sure Chun or Lon do as well, so we should have a good selection of shims).
Maybe there's a less invasive way to do this (don't have time to view the videos and other resources now), but Chun had to remove/disconnect the steering column, steering rack, sway bar, reinforcement plate, subframe, engine mounts, FCABs, and headlight auto leveler. The subframe and a few other things have one time use bolts that require replacement, torque to spec, and angle torque.
      03-16-2013, 03:59 PM   #29
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Huh. Can I bribe you guys with beer? I'm due for a valve adjustment (already have all the parts for that). Was considering getting the exhaust hub replaced while I was at it.
You guys are going to have to consult with Chun. He did the work for me. I only did the easy stuff
He's a busy guy so hit him up early if you want any hopes of scheduling a time to do your valves, check/upgrade cam bolts, and check/upgrade exhaust hub.
      03-16-2013, 04:58 PM   #30
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
I like to watch and learn too. Sounds like this will take at least half day to complete.
      03-16-2013, 05:16 PM   #31
beta
Great! the more the merrier. I'll post day for all the bay area folk that want to show up and help or just watch. I went ahead and got a new exhaust hub and sent it to turbotoy to get modified, so I'm committed at this point.
About the micro-torque wrench. Have the same issue, my torque wrench is 25-135Nm (roughly 20ft/lb to 125ft/lb).
I don't want to get a spring click torque wrench because those require re-adjustment periodically. Which leaves me with a dial wrench or a fixed torque wrench.
The dial wrench will be more versatile but hard to look at in tight spaces. I did find a model that lights up when you reach a desired torque.
I'm leaning to a fixed head wrench. I only remember hearing 10Nm in the video, but I'll watch it again. If there's only a few set torque numbers, a fixed torque wrench with a few calibrated heads might be good for the <20Nm uses.
Yes, doing valve adjustment at the same time. Already got a shim kit
The videos are for e46, I still don't know how much surgery this is going to require. I really hope it's not that involved. I'm going to check TIS see what it says.
      03-16-2013, 06:12 PM   #32
RobMCoupe
RobMCoupe's Avatar
60
I have Craftsman 3/8" Electronic Torque Wrench, 10-100 ft-lbs Model 947711. The lowest is 14 nm. The display provide current torque value.
      03-16-2013, 06:22 PM   #33
beta
Thanks Rob, looks like it's also too high for 10Nm.
I got TIS printing to pdf! The preliminary necessary tasks only mention fan + things you'd do for valve adjustment.
It's going to be great to have extra hands, we can take a ton of pictures and make a really good DIY for this. Really looking forward to it.
File Type: pdf job_11-replacing_VANOS_adjustment_unit__S54_.pdf (5.66 MB, 122 views)
      03-16-2013, 06:35 PM   #34
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Odd that they don't say much about timing.
      03-16-2013, 10:56 PM   #35
Shipkiller
Shipkiller's Avatar
Drives: Me
I have more valve adjustment information here: http://www.shipkiller.com/S54_Valve_Adjustment.html
      03-17-2013, 01:31 AM   #36
mgwatson48
mgwatson48's Avatar
Drives: 2008 E86 M
^^ Great website ship! I will definitely be referring back to that when I need to! Bookmarked!
SOLD: 2008 M Coupe
      03-17-2013, 03:17 PM   #37
beta
Thanks Ship great page. The individual shims and the worksheets are really useful, definitely going to use those.
      03-28-2013, 10:44 PM   #38
beta
Parts came in the mail today. The timing tool is real heavy, I got the second pin for it too to make things easier.
Just waiting on the exhaust hub to get modified and sent back and I'll set up a day for exhaust-hub-fest
Still don't know what I'm going to do for the 10Nm torque tool.
      03-29-2013, 08:20 AM   #39
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Second pin?
Are the pins separate part numbers from the tool?
      03-29-2013, 09:07 AM   #40
RobMCoupe
RobMCoupe's Avatar
60
Second pin?
Part number is 83300491086. I thinking about getting the cam timing tool.
      03-29-2013, 09:46 AM   #41
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Thanks
I'm planning to get it as well, but I have so much on my plate right now, I think it will have to wait until next year.
      03-29-2013, 10:29 AM   #42
RobMCoupe
RobMCoupe's Avatar
60
Thanks
I might have my son buy this for me. His E36 M3 might need head gasket job. I in the same boat having too much going on this year.
      03-29-2013, 12:44 PM   #43
beta
Second pin?
Comes with one pin and you're supposed to remove it and move it to the other side. See the picture that ship linked at the top of page 2 of this thread.
You can buy a second pin, then you can just leave both in. I saw it in a few of the DIYs and thought it was a good idea.
Also, my hub is done! getting shipped soon.
      03-29-2013, 12:51 PM   #44
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Thanks Great info... That makes a lot of sense.
