      08-26-2011, 01:44 PM   #23
Beedub
Originally Posted by Roffle Waffle View Post
yeah I'm at -20 at warm idle, but it fluctuates ever so slightly with the idle RPMs
fluctuates by how much?? some movement will definatly occur.
      08-26-2011, 03:37 PM   #24
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
by 1psi up and down, matching minor fluctuations of the idle
      08-26-2011, 03:43 PM   #25
Beedub
i dont think thats abnormal tbh.....
mine only desnt fluctuate because my idle doesnt move, it would with idle movement, i dont think you have a vacumn leak tbh.
      09-02-2011, 09:23 PM   #26
iPhoneEngineer
Drives: 2007 BMW Z4 M Coupe
Roffle, how do you like the Bavauto coils?
      06-01-2013, 10:00 AM   #27
abashoe
Drives: 2008 335xi
Bumping an old thread. How have the ignition coils worked out for you?
      06-03-2013, 04:52 PM   #28
iPhoneEngineer
Largely due to the discussion here, I never actually got the coils. Consensus seemed to be that the stock coils are quite good. I replaced my spark plugs, which helped slightly but noticeably. Then I had to ship the car to ESS (at my expense—$1100! ) for further debugging, and they found an issue with the tune that was corrected and solved the biggest problem with my car.
Having the nicer coils would be an awesome peace of mind, but the cost-to-benefit ratio is just a bit worse than I can bear. Rather save for an exhaust system or new paint job .
      06-03-2013, 05:09 PM   #29
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6158
Drives: ‘06 Z4MR, ‘20 X7, ‘22 M4x
Originally Posted by iPhoneEngineer View Post
... in my everyday commute (very much unlike a usual commute)...
Those roads going to La Honda from Skyline Blvd are sweet lucky you
      06-03-2013, 05:13 PM   #30
ZStig
279
very much. I believe I picked up some mid-range power, but I haven't dynoed since I've had a boost leak with my initial install
      06-04-2013, 01:19 AM   #31
StickMon
StickMon's Avatar
Drives: 2006 MR
Aren't the Bavauto coils just these with red caps stuck on them?
But I do like the red caps.
I just bought these. Couldn't pass up the price.
      06-04-2013, 05:40 PM   #32
ZStig
279
supposedly the bavauto coils have upgraded internals over stock. I don't remember
