      01-19-2010, 10:36 PM   #1
andrewj7
Drives: Z4 Coupe (#40) w/Nav,Sprt,Prem
auto-sensing wipers not working
The auto-sensing wipers on my 2006 Z4 Coupe have basically never worked right. They come on when it's cold, don't come on when it starts raining. However, when its been raining for 20 minutes, seem to get with the program and start working. This happens at any level of the intermittent setting (when in one notch up from the off position on the right level)
Does everyone else have this issue? Could it be that I need to clean the sensor or the window in front on the sensor with something special?
Given that i live in California, this isn't something that bothers me a lot of recent storms make it annoying.
2006 Z4 Coupe, Silver Grey, Sports Package, Premium Package, Navigation System, Intravee II + Alpine KCA-420i, Heated Seats, Xenon Headlights
      01-20-2010, 07:27 AM   #2
ZEDMFOUR
Drives: 2006 Z4M Roadster
Check for a delaminated windshield around the rain sensor. This is the black portion of the windshield in front of the rear view mirror. Look at it from the outside and if it's delaminating you will see an air pocket and or tell where it is loose or not adhering. If you see this that's the problem. I had the problem on a 2005 2.5. It is a warranty fix assuming you still have some left. If not $400-$1000 depending on outside repair or dealership.
      01-20-2010, 07:52 AM   #3
imz4n
imz4n's Avatar
Drives: 2006 3,0 si TITANIUM SIlVER
IIRC the Dealer replaces the whole windshield when done under warranty. I also assume that all other settings work fine?
SoCal Z Enthusiast contact me to get on the list. Events for like minded people and when you talk about your Z, we will know what you are saying. https://www.facebook.com/groups/ZSCCACalifornia/
      01-20-2010, 10:24 AM   #4
andrewj7
I'll check that out.
And yes, all the other wiper modes work just fine.
      01-20-2010, 01:01 PM   #5
skim
Drives: 07 Z4MC
Mine's working well, especially when put to test in recent days with all the rain storms in CA.
One thing tho is when I leave the wiper in the auto mode and turn off the car, when I turn it back on, the wiper never operates. I have to switch to "off" then back to auto in order for it to start. A little annoying but I can live with it unless it's a defect?
Future mod consideration: exhaust, pulley
otherwise, very happy with how the m3 was born
      01-20-2010, 02:11 PM   #6
MetMan
MetMan's Avatar
14
Drives: 2003 Z4 3.0i, 2033 X5
Skim, mine operates the same way. I just assumed that it was normal.
      01-20-2010, 03:24 PM   #7
The__J__Factor
The__J__Factor's Avatar
Australia
88
Drives: ///M Coupe
Mine never auto starts but if its in the first setting it will either speed up as the rain gets heavier or slow down when it settles.
135i N54 manual
MR-S with a 2zz swap and mods Sold
EVO X MR - Phantom Black - Ti Exhaust - Ti UICP - AQM Intake - Sold
Z4 M Coupe - H&R - RE Diablo - RPi - Tekarbon - Sold
      01-20-2010, 03:31 PM   #8
skim
Drives: 07 Z4MC
cool I guess it's normal. Thx!
      01-20-2010, 08:08 PM   #9
caseysc
caseysc's Avatar
Drives: 2010 128i Conv.
2005 Z4 2.5i  [8.00]
The rain sensor funtion must be reset every time you turn off the ingnition. After starting the car, just place the stalk lever to off and then back to intermittent.
If the rain sensor is not working at all, BMW replaces the entire windshield with a new mirror already in place. At least that is what they did with mine two years ago. It was under full warranty so I have no idea what it would cost.
      01-20-2010, 09:30 PM   #10
U235
23 BMW X7 M60i, 22 Volvo V60 Polestar Engineered
U235's Avatar
599
Drives: 23 X7 M60i, 22 Volvo V60 Pole*
I was thrown off by this as well, doesn't make much sense, but I do love the auto-sensing wipers. I had a 328i (2009) loaner and found the Z4s to be far more accurate. The 328i's auto rain sensor didn't seem to run fast enough for me, too much water would collect before it would decide to wipe. The Z4's programming seems spot-on for me.
      01-20-2010, 10:51 PM   #11
VitaminT
Drives: 2006 M Roadster
Is there a way to adjust the sensitivity on the rain sensing wipers? The little wheel in the stalk doesn't seem to do the trick, in fact not sure what it is for.
      01-21-2010, 09:16 PM   #12
lo-tek
I'm a PC
Drives: 2012 135i M-Sport Coupe
That behavior is by design.
