      01-12-2010, 08:49 AM   #1
BMWI6
BMWI6's Avatar
Colombia
96
Drives: 335is
z4 navigation problem?
Hi guys, I have noticed that when I want to use the navi on my z4m and I want to see the highlighted route on the map when Im getting directions, the highlighted route is white which is very similar to the beige color of the map. This makes nearly impossible for me to see the route. Is there any way to change the color? And is there any way I can get an updated map with current businesses for the gps? Thanks
If everything seems under control, then you aren't going fast enough"
      01-12-2010, 09:31 AM   #2
jragan
Imola Lover
jragan's Avatar
The highlighted route should be white. You could probably change the color of the line with NavCoder or NavTweak . You might also try switching to the other color scheme in settings to see if that helps you.
Hers: 997-1 C4S: Pics
      01-12-2010, 10:14 AM   #3
wildag
///M'n it Up
wildag's Avatar
Drives: '06 ///M Roadster
Yea, the default white line is hugely annoying.
I used NavTweak to change the line to bright purple.
Go look at the stickies in the "Navigation" forum at xoutpost.com
      01-12-2010, 11:51 AM   #4
BMWI6
BMWI6's Avatar
Colombia
96
Drives: 335is
Thanks for the help guys, I guess Im going to try to use the sticky, but it seems really complicated. One last thing, is there any way to update the GPS database? Businesses and attractions change all the time, so the navi becomes outdated very quickly. thanks
      01-12-2010, 01:20 PM   #5
CalRick
Drives: '15 M235 & '95 M3 tracktoy ;
2016 X3 Xdrive28d  [0.00]
2015 BMW M235i  [0.00]
1995 BMW M3  [0.00]
Yes, you can get updates from Navteq for $200, but their current "update" is over a year old - released 9/2008.
