07-20-2022, 11:21 AM | #2707 |
Not great. Not terrible
7448
Rep 2,700
New alternator and battery.
Steering wheel rewrap by Royal Steering Wheels (took it with my on my trip to England, packed in my luggage )
Current: 2024 BMW X3 M40i.
07-20-2022, 02:12 PM | #2708 | |
Rep 4,058
07-20-2022, 02:56 PM | #2709 |
Rep 783
Yes, I have only used the Autoglym interior protectant and tire dressing, both are excellent products.
2008 E86 M coupe
07-23-2022, 04:13 PM | #2712 |
Rep 566
Coming from some of my previous cars when I first changed my O2s, plugs/coils/oil change in my Z4 I thought to myself my car must be broken it’s just way too easy and accessible to work on it. I actually had a nervous feeling if I was missing something when I was all done.
JustinHEMI7448.00 |
07-23-2022, 04:28 PM | #2714 |
7448
Rep 2,700
Whew that was easy. Turns out you can't rely on the lever of the connection to fully seat itself. 3rd coil barely plugged in. Check them all, none of them were fully seated.
Lesson learned!
grannyknot953.00 |
07-23-2022, 07:53 PM | #2715 | |
Rep 783
It's good that you noticed otherwise you could chase that problem for a while.
2008 E86 M coupe
JustinHEMI7448.00 |
08-05-2022, 02:09 PM | #2716 |
7448
Rep 2,700
3M headlight restoration kit. I thought my headlights were pretty well gone, but they came back not too bad. Not perfect, but much better than before. Hopefully they'll last until I can try to put the new lenses on..., or am forced to pay the exorbitant prices for new ones.
08-05-2022, 02:10 PM | #2717 | |
Rep 202
2006 Z4 ///M, Interlagos Blue/Beige
racerbruce3854.50 |
08-05-2022, 02:13 PM | #2718 |
7448
Rep 2,700
Yeah I got the 3M kit because it comes with a UV clear coat. I'm glad to hear they hold up well with that.
racerbruce3854.50 |
08-30-2022, 02:53 PM | #2719 |
Get off my lawn
938
Rep 1,161
A long time coming, bit of an overhaul
Next up is a replacement Eventuri intake air filter, brake fluid flush and first wash for 2022 |
09-06-2022, 04:58 PM | #2721 |
Rep 27
Retrofitted the Aux/USB from a F10 I found on eBay, I wanted a extra charge port that looked OEM. Only hard part was finding the 4pin to USB cable… other than that it was a success!
09-06-2022, 08:29 PM | #2722 |
Rep 977
09-06-2022, 10:25 PM | #2723 | |
Rep 27
BMW Aux/USB - [P/N] 84109237653 *make sure it has 4pins on the back for the AUX* 4 Pin to USB A - https://www.amazon.com/dp/B0783Q1BXV...roduct_details Everything else is just hardwiring to your liking. I fed the wire through the console and out by the passenger footwell. It was very tricky but possible. Last edited by MVRS; 09-06-2022 at 10:48 PM.. Reason: Correction |
09-14-2022, 07:35 AM | #2724 |
Rep 13
Drives: BMW Z4 2004
right hinge
After replacing the left hinge through my dealer and lasting one day the right hinge went, so they say and now they suggested that I replace the pump for another $1200 as preventive maintenance seeing that everything is apart right now. My dealer was charged $2900 for the left hinge alone. What a racket. I have had three versions of what they did replace and I don't believe any of them. Never saw a receipt since my dealer was paying for it,
I will take a beating but I am getting rid of this Z4 even though I love it. It is 18 yrs old with 53K on it. David F |
09-14-2022, 07:40 AM | #2725 |
Rep 13
Drives: BMW Z4 2004
P.S. if you click on my name and then profile you will see a photo of the car and rims. I am having a hard time trying to find out what rims they are as I have to replace two of them.The dealer said they are not allowed to spin balance these particular rims. I am stuck and have to replace them myself.
David F |
09-18-2022, 10:03 AM | #2726 | |
Rep 430
if you take one wheel off you can examine what is written on the back of it to determine the brand and specs. But generally any wheel can be balanced. Not sure what the problem is. But again its the dealer trying to take all your money I think. Wheels can have different issues. |
09-18-2022, 07:08 PM | #2727 |
E86 M Coupe
265
Rep 406
Got my rod bearings (ACL), VANOS bulletproofed with new upper chain guide (Beisan Systems), valves adjusted, belt and tensioners, (034 motorsports) motor mounts, cpv valve seal by KAIV (Highly rec’d!) my M Coupe has 65K miles upon removal
09-19-2022, 02:27 PM | #2728 |
Rep 13
Drives: BMW Z4 2004
Thanks for the reply belcum.
I have been going crazy trying to find out the rims. I just got the car back from bmw-another $1700 under dealer warranty plus the first $2900 that comes to $4600 in a month. I think there are a lot of guys driving these older z4's in manual operation. David |
