      11-05-2009, 02:10 PM   #1
BMWI6
BMWI6's Avatar
Colombia
96
Drives: 335is
Want to change tranny oil. how to?
Hi, I want to change the tranny oil on my z4m. does anyone know which oil I need to use and I also heard that I should replace the one on my differential, can someone tell me which one to use and what else I should change on the car. Any filters or stuff like that. thanks!
If everything seems under control, then you aren't going fast enough"
      11-06-2009, 01:39 PM   #2
jmillet
jmillet's Avatar
64
Do a search on the Bimmerfest Z3/Z4 forum and you'll find out more than you want to know.
Buy a TIS DVD on EBay and you'll get the official version.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      11-06-2009, 02:50 PM   #3
Leonardo629
Taiwan
168
Drives: 2013 M3 Coupe
what Jim said, Ron has posted some underneath pics of his Z4M on bimmerfest.
I just did the change myself, I used Motul 300 competition gear oil, the color is gold. You'll need two buy two bottles.
      11-06-2009, 03:03 PM   #4
pbdm4k
pbdm4k's Avatar
Drives: 2010 335d
Make sure you check with the manufacturer if their oil is rated for the car.
Not all oils are created equal, needless to say.
I am using Redline D4ATF without problems, and MUCH smoother shifting.
I needed a little over 2 bottles.
2010 BMW 335d "Ha! She wants the D."
2006 VW Jetta 2.5
Once upon a time...
'03 VW GTI, '99 Audi A4 1.8TQ, '00 VW Jetta 1.85T, '09 BMW 335i xDrive, '04 BMW Z4 3.0i, '01 Audi TT 1.8T, '04 Volvo S80 2.5T
      11-13-2009, 08:57 AM   #5
wrh3
Car Guy
wrh3's Avatar
31
Drives: 2005 MCS, 2013 Corvette 427
I used Royal Purple Synchromax, I have some info/pics on my website from when I changed mine.
Bill- 2005 Mini Cooper S, 2013 Corvette 427
www.billswebspace.com/bmwindex BMW CCA Member # 389948
      11-13-2009, 04:41 PM   #6
AWM3
BMW Fan
AWM3's Avatar
11
Drives: 2012 E92 M3, Alpine White
Change the oil while hot.
Place the car on jackstands so it is level.
Loosen the top (fill) plug first. Make sure you have the right tool.
Remove the bottom plug, let the oil run out, replace the plug.
Use a little pump available at auto parts stores to fill the trans or diff to the level of the fill plug, so the oil just begins to run out. Replace the fill plug.
Redline products would be D4 ATF for the trans and 75/140 gear oil for the diff.
http://www.turnermotorsport.com/html...=E46M3-REDLINE
      11-13-2009, 05:08 PM   #7
mhughett
Drives: 2007 Z4 M Coupe
I thought Mike Miller who does all of the technical correspondence for the BMW Roundel always recommends 75w/90 oil in the differential for all BMW's. Is there a reason to use the 75w/140? Also, he recommends Redline MTL instead of the D4ATF although admits that some use a 50/50 blend of these two products in the gearbox and have had very good results.
Retired--2007 Z4 M Coupe (Imola Red/Black, Premium Pkg, Heated Seats, XM, Bimmian stubby antenna, CDV delete, Apex EC-7--Anthracite, Goodyear F1 Asymetric 2.
      11-13-2009, 05:31 PM   #8
AWM3
BMW Fan
AWM3's Avatar
11
Will Turner is a little more authoritative than Mike Miller, since he races and wins championships with these cars. The diff in the Z4M is the same as in the E46M3. It requires the 75/140 lubricant. Redline MTL is not appropriate for the newer BMW transmissions which are designed to use an ATF type fluid.
      11-14-2009, 07:51 PM   #9
jmillet
jmillet's Avatar
64
Will Turner is a little more authoritative than Mike Miller, since he races and wins championships with these cars. The diff in the Z4M is the same as in the E46M3. It requires the 75/140 lubricant. Red line MTL is not appropriate for the newer BMW transmissions which are designed to use an ATF type fluid.
BMW has been calling out an ATF for their manual transmissions for years now. That's one reason Red Line introduced their D4-ATF for manual transmissions. It's basically relabeled MTL. I use a 50/50 blend of MTL and MT-90 in my Bimmer manual transmissions after the car is out of factory warranty. Until then I use Castrol MTL-LT-2.
Jim Millet
      11-14-2009, 07:54 PM   #10
BMWI6
BMWI6's Avatar
Colombia
96
Drives: 335is
thanks for all the responses guys. My car has 19,000 miles, am I being too cautious and should I wait a little, or should I do it now?
      11-15-2009, 06:02 AM   #11
AWM3
BMW Fan
AWM3's Avatar
11
We are assuming that the 1200 mile service was properly done at a reputable dealer and the transmission and diff fluids were changed at that time, right?
In that case, if the car is never driven on a racetrack, it is too early and I don't think you will gain anything by changing those fluids after so few miles. If it is a track driven car, they should be changed much more frequently.
      11-15-2009, 06:58 AM   #12
BMWI6
BMWI6's Avatar
Colombia
96
Drives: 335is
Hi, yes, the 1200 mile service was done. I dont take it to the track, but I do drive it very spiritedly. When should I change the fluids then? thanks
      11-15-2009, 10:14 PM   #13
jmillet
jmillet's Avatar
64
E85/86 M Roadster and Coupe transmission fluid and differential oil are replaced at Inspection II per the BMW NA Service Maintenance Checklist:
http://www.bimmerfest.com/forums/sho...d.php?t=171200
http://www.bimmerfest.com/forums/sho...2&postcount=21
Jim Millet
