      12-20-2014, 02:53 PM   #1
bjbstewart
bjbstewart's Avatar
Drives: 2007 BMW Z4MC
FS: Various M items: Springs, aFe, Cover
Got a few things I need to move. Will ship in Cont US for $10. Paypal add 2%. PM with questions...
1) aFe intake kit: $395 - E85/E86 Z4 M Roadster, Z4 M Coupe - Stage 1 ProDry S. Less than 500 miles, box, manuals, all parts.
This intake kit replaces your restrictive factory air box. It features a 1.6mm powder-coated steel heatshield that blocks hot air from entering the filter. Each intake kit has a custom application-specific aFe cone filter that replaces the stock panel filter. The larger aFe filter, combined with the heat shield allows more air to flow to the engine. By removing your stock intake air box, you are removing the most restrictive portion of your intake system, increasing both horsepower and torque, improving acceleration and throttle response, and producing a more-aggressive engine note. Step-by-step instructions for a quick and easy install are included. aFe reports a gain of 11hp and 10ft/lbs of torque on the Z4 M.
see: http://www.turnermotorsport.com/p-19...-prodry-s.aspx
2) BMW Car Cover: $100.
Part #: 82110417600 (82-11-0-417-600)
Get a car cover that is custom fit for your BMW, not some generic one size fits all available from other suppliers. This Genuine BMW car cover is custom fit specifically for the E85 Z4 chassis.
NOAH barrier fabric actually stops water, yet it "breathes" to allow any trapped moisture, seam seepage or condensation to easily evaporate. The unique construction process (patent pending) results in a cover with maximum all-weather protection...highly water resistant, dust resistant, UV resistant and breathable to make sure moisture and/or heat don't stay under the cover. Made in the U.S. the fabric weighs only 4.75 oz./sq. yd., so it's easy to handle and fold.
Protective Outer Layers - A bi-component spunbond, using sheath-core technology. The inner core is polypropylene for strength, with a polyethylene wrap for softness. A silver-gray color was selected because of its heat-resistant properties. The fabric is also treated with UV inhibitors for extended outdoor use.
Micro-Porous Middle Layer - The barrier layer is breathable film, a proprietary stretch-film technology. The film is stretched and subjected to a chemical process that creates microscopic holes smaller than droplets of water or dust, yet large enough to allow moisture vapor to escape.
Soft, Paint-Protecting Inner Layer - A bi-component fabric made with polyethylene and nylon. This combination results in an exceptionally high strength-to-weight ratio, with the "soft touch" necessary for today's water-based paint finishes.
This car cover fits the following BMWs:
2003-2008 Z4 BMW Z4 2.5i Z4 3.0i Z4 3.0si Z4 M Roadster M Coupe
3) Eibach Lowering Springs: $250 New in Box Part number 2095.140
Front: 0.8" / Rear: 0.4"
The Eibach Pro-Kit is the perfect answer for most frequently-driven street cars. It´s our legendary spring system that dramatically improves both a vehicle´s performance and appearance.
Pro-Kit lowers your car´s center of gravity, reducing squat during acceleration, body roll in corners and excessive nose-dive under braking. When combined with Plus-1 or Plus-2 wheels and tires, the Eibach Pro-Kit is the finishing touch to a winning recipe for performance. Pro-Kit also reduces excessive fender-well clearance, making your car look just as hot as it performs.
Every Eibach Pro-Kit is designed and tested by our suspension engineers and performance driving professionals, to deliver aggressive good looks and high performance handling, without ever compromising safety or ride quality. By using our proprietary, progressive spring design, Pro-Kit provides the ultimate balance to take your passion for driving to a whole new level.
- Features:
•High Performance Handling and Aggressive Good Looks
•Lower Center of Gravity -- Lowers Vehicle 1.0" - 1.5"
•Stop Quicker, Corner Faster and get Better MPG
•Progressive Spring Design for Excellent Ride Quality
•Million Mile Warranty
See: http://www.nopi.com/dsp_part_detail....vt=n&vmakeid=0
[SIGPIC][/SIGPIC]
      12-29-2014, 04:34 PM   #2
Phamee
Drives: '07 Silver Z4 M Coupe
PM'd. I'll take the car cover. Thanks.
2007 Z4M Coupe [Silver Metallic | Black]
1984 318i [Alpine White]
      12-30-2014, 09:47 AM   #3
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
I'll take the cover! Pm me your info
      12-30-2014, 01:59 PM   #4
PLCZ4MC
Proud E86M Owner
PLCZ4MC's Avatar
$300 solid for the afe?
      01-02-2015, 01:13 PM   #5
bjbstewart
bjbstewart's Avatar
That's a little light. It's virtually brand new and in perfect condition. $375 will take it, including shipping to cont us...
[SIGPIC][/SIGPIC]
      01-04-2015, 07:46 PM   #6
Phamee
Great seller and awesome overall car guy! Thanks again Brent!
      01-06-2015, 09:59 AM   #7
bjbstewart
bjbstewart's Avatar
You are welcome, enjoy!!
[SIGPIC][/SIGPIC]
      01-06-2015, 10:00 AM   #8
bjbstewart
bjbstewart's Avatar
aFe and Cover are gone. Still have the springs...
$250 shipped to Cont US.
[SIGPIC][/SIGPIC]
      01-17-2015, 11:50 PM   #9
RossBMWZseries
You stated you had 0.8 in front and 0.4 in rear, but Eibach claims anywhere from 1.0 to 1.5. Why the discrepancy?
      01-18-2015, 11:03 AM   #10
Dalecan
Dalecan's Avatar
102
Drives: Aston V8VS, F85 X5M, TVR, 128i
Afe was in perfect condition, thanks! Bump for a great seller.
      01-30-2015, 06:44 PM   #11
bjbstewart
bjbstewart's Avatar
You are confused. I am on the Eibach site right now. .8 front, .4 rear.
[SIGPIC][/SIGPIC]
      02-02-2015, 01:59 AM   #12
RossBMWZseries
Probably true. On your original post under "features" for the springs, it reads "•Lower Center of Gravity -- Lowers Vehicle 1.0" - 1.5"
Tags
afe, cover, eibach
