07-03-2015, 02:35 PM | #1 |
Rep 54
06 3.0si Oil Level and Reset
Hi,
I just changed my oil w/6.9qts and when I checked the level it looks to be low (please see pix) is it low or is that normal? Could it bee that I did not add enough oil??? If I reset the oil check (unsure on how to do that) would the oil level read correctly? TIA, John |
07-03-2015, 08:00 PM | #2 |
Rep 18,722
It's probably providing the previous oil level prior to the oil change. Let it cycle through the oil level reading process and it should real full.
07-04-2015, 04:05 PM | #3 |
Rep 1,224
Take it out fo a drive and you should have an accurate reading next time you drive the car/check the level. For some reason, not all of our cars give the correct reading immediately after an oil change. Each block is about 1/4 liter or quart IIRC, so you're 1/2 liter/quart low. FWIW the TIS suggests filling to 6.5 quarts and topping off as necessary once warm.
07-05-2015, 07:22 AM | #4 |
Rep 106
This - I've found that it can take 40-50 miles - couple of run cycles - before it shows the new, correct level. This kind of lag is pretty annoying but it's all we have. If you put 6.9 in there, you will be fine.
