09-15-2009, 04:17 PM | #1 |
Rep 52
Issue with my Z4's navigation
Hey guys, I've got a strange issue with my GPS. It isn't finding any satellites its always searching. Is there a way to reset the GPS or something? Could it be there is a cable loose or something?
When I go into the hidden settings menu this is what I get for the GPS
2005 BMW Z4 Roadster - 3.0l, SMG, M Seats, Eisenmann exhaust and Hardtop.
09-15-2009, 07:36 PM | #2 |
Rep 1,034
It's not uncommon for the GPS antenna to go bad for whatever reason. Mine is on the way out, the S/N ratio numbers are all under 5 and heat seems to effect it making it loose the signal.
09-16-2009, 02:02 AM | #3 |
Rep 52
Is it a easy fix? I mean if i bought the part myself could I install it? It gets REALLY hot in Kuwait so if heat kills it then I understand how that happened.
09-16-2009, 01:08 PM | #4 |
689
Rep 6,854
The GPS antenna on my Z4M went out as well. Had it replaced under warranty by the dealer. As for install, I know it involves removing the headliner (took the dealer a day to do).
Travis Williams
Shop ALL BMW G80 | G82 Parts Here! 480.966.3040 ext 318 Travisw@vividracing.com PM, Email, or Call Directly for aggressive BMW Member Pricing |
09-23-2009, 11:48 AM | #5 |
Rep 52
Ok just an update. A few day after i posted the car battery died. I replaced it awhile ago and the gps started working again finally. Not sure if the weak battery was the cause or if it was The action of disconnecting the battery and reconnecting it which would have cause a hard reset of some sort that got it working.
09-23-2009, 12:00 PM | #6 |
689
Rep 6,854
Hmm... not sure.
Either way, if changing the battery did the job, consider yourself lucky; just saved yourself extra time/money!
Travis Williams
09-25-2009, 03:07 AM | #7 |
Rep 95
I would not remove the headliner anyway. A new GPS antenna is $10 from eBay and you can clip it next to the airvent on the metal bracket inside the dash.
That is where I put mine on the previous Z where I retrofitted the OEM satnav system. |
10-22-2010, 09:49 PM | #8 |
Rep 198
Think I mine might be starting to go. I lost satellites last Sunday on the way home, and to night on my way to get my Niece a her college - what a pain luckily I have GPS software in my iPhone.
I'll have to check it out |
10-23-2010, 04:10 AM | #9 |
Rep 160
Drives: 2007 BMW Z4 M Coupe
All I will say is I'm glad my M has all the options available except the navigation.
10-23-2010, 10:53 PM | #10 |
Rep 1,034
I replaced my GPS antenna with this one. http://cgi.ebay.com/ws/eBayISAPI.dll...m=160492431145 looks exactly like the one I had.
It was easier then I thought it would be to replace. I just popped off the dome light then removed the visors. The plastic had enough flex that I didn't have to remove any more.
10-25-2010, 11:02 AM | #11 |
Accountant, 1st Class
Rep 237
Drives: 2006 Z4 3.0si Roadster, Black
Bad navigation antenna
I was wondering what caused my NEW Nav system to stop working.
We just had a new Kenwood DNX 6960 Nav/sat.radio/DVD/Bluetooth/rear camera installed. We had it installed for LESS than 24 hours. We drove to Canton and the Z4 spent the day in the sun (88degrees). Got in to come home and the satellite would not hook up to a satellite. Just kept searching. Got home and cycled the ignition switch and it began working just fine. Top down the whole way, ie no A/C Could the heat from the sun have caused the glitch? Hasn't happened since. The Nav antenna is lying on the black interior dash close to the windshield in the center of the car so it has a direct upwardly view of the sky. |
