12-15-2011, 08:54 PM | #1 |
Rep 49
Dodged a bullet + found an honest indy shop in Austin
Since I returned to Austin, I haven't found an indy shop yet. I knew it was close to time to replace the rear differential mount bushings. BMW of Austin wants $1200 to do the job so I decided to find an indy and get it done next month.
So last Sunday, I start to hear a terrible squealing and scraping coming from my left rear wheel. I immediately thought wheel bearing but without a jack, there was no way to see if the wheel moved back and forth. I couldn't see any problems when I looked underneath. Monday, I had it towed to Paul's Motor Werks here in Austin expecting that I was probably going to end up replacing a wheel bearing and if one goes the other usually follows. Monday night, I get a call from Jack at PMW and he says my car is good to go. They removed the wheel and found a small rock lodged between the rotor and the heat shield. Apparently he had to jump through a few hoops to get it to come out but he did. I had to reimburse them $75 for the tow but they didn't charge me a dime for the work. Jack also told me I probably had another six months before I needed to replace the rear differential bushings but when I was ready, they'd charge me $525. I'm pretty impressed with them. |
12-16-2011, 01:17 AM | #3 |
Rep 1,530
We should keep a thread with names, phone numbers and locations of honest shops around the country.
12-16-2011, 06:58 AM | #4 |
Rep 1,991
I had that same issue in a Mazda 323 GT I had in college. Very scary sound eh? Glad you found someone who was honest. I probably would just had the bushings done while it was there to save another trip.
12-16-2011, 11:15 AM | #5 | |
Rep 49
I've got a trip coming up next week so I'm going to drop it off on my way out of town and have them take care of a couple of oil leaks and do the bushings then. |
Tags |
austin, indy, shop |
