04-30-2024, 07:44 PM | #3 |
Rep 430
I used ARP when mine were done. They're reusable by the way. So that is probably the main benefit.
Do make sure to check if yours are 10mm or 11mm. From Bimmerworld: This rod bolt set is made for the later S54 (February 2003 and newer production dates), which used an M10 sized bolt, versus the earlier cars which used an M11 sized bolt. (If your S54 engine is built before 02/2003, or you know it has an M11 sized bolt, please see BimmerWorld part # 201-6103 instead.) https://www.bimmerworld.com/Engine/G...02-03-M10.html |
