      07-08-2013, 03:25 PM   #1
ZcuatroM
Drives: 2006 Z4M Roadster
Clunk sound from the rear
Hi guys, I have read a few threads about this, but they all seem to be different. I have a loud clunk sound when turning or when driving from 1-10 mph. Some say its the LSD others say it some traing arm bushing. Have any of you gine through this?
      07-08-2013, 11:53 PM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
Mine's done this about 1/2 dozen times, or something like it, when first turning out onto the highway near the house and jumping on it. Can never get it to repeat.
Wrote it off to the diff being cold or not getting enough oil splashed around in it yet.
I don't do that any more. I go a little easy on it for the first 5 minutes or so when cold, and haven't heard a peep out of it.
      07-09-2013, 12:49 AM   #3
RobertRO
Romania
Drives: Z4 M Coupe
I also had a clunk sound, very seldom. While doing some work on the rear wheels I discovered by chance that the right side bracket of the rear sway bar was completely gone. For God knows how long time.
I replaced it and the cluck was cured.
      07-09-2013, 08:51 AM   #4
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
^ Common. When I checked last year, I was missing a bolt on one side, and the other bracket was completely gone.
      07-09-2013, 07:15 PM   #5
StickMon
StickMon's Avatar
Drives: 2006 MR
#3 ?
I know what I'll be checking this weekend. Thanks for the heads-up.
      07-14-2013, 06:24 AM   #6
Kim Schwartz
Drives: 128i
Originally Posted by StickMon View Post
#3 ?
Attachment 886073
Me too. I sometimes get the same sound.
      07-16-2013, 12:48 PM   #7
mike519
mike519's Avatar
Drives: 2018 M240i
Could be the LSD as well...this is also common. If so, switch to the BMW oil with the friction modifier booster.
      07-18-2013, 08:48 PM   #8
Kim Schwartz
Drives: 128i
still clunking
Well I tightened everything in the rear swaybar assembly, nothing was really loose, and there is still an occasional clunk from the right rear in low speed corners. It happens most often if the transition is more abrupt. Could this be the LSD? Any thoughts would be appreciated.
      07-18-2013, 11:36 PM   #9
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
Did you inspect rear shock mount?
      07-19-2013, 07:34 AM   #10
Kim Schwartz
Drives: 128i
No. I don't know how to do that. Is there a tutorial somewhere?
      07-19-2013, 08:10 AM   #11
MZHammer
MZHammer's Avatar
45
Drives: E85 Z4M, F82 M4
2016 M4  [0.00]
2006 BMW Z4M Roadster  [0.00]
My LSD was noisy during the first test drive. The dealer did the diff fluid swap, with modifier and it cured it.
      07-19-2013, 12:47 PM   #12
Kim Schwartz
Drives: 128i
How can I be sure that it is the LSD? It is a 2006 but it has only 12k miles on it. I have owned the car for about six weeks.
      07-19-2013, 06:06 PM   #13
MZHammer
MZHammer's Avatar
45
2016 M4  [0.00]
I don't know enough to give you solid advice on that, but I can tell you that my car had diff noise with only 19k miles on it. Not sure if that helps you at all though.
      07-22-2013, 11:28 PM   #14
RobMCoupe
RobMCoupe's Avatar
60
You have to remove interior trims to get to the shocks. I would change to Rogue RSM to avoid removing the interior in the future.
      07-23-2013, 04:55 PM   #15
Kim Schwartz
Drives: 128i
The car is a 2006 with 11k miles on it. Do you think it needs new rear shock mounts at this point or possibly something is just loose?
      07-23-2013, 06:47 PM   #16
RobMCoupe
RobMCoupe's Avatar
60
OEM ones are not very sturdy. It is at least 6 years old and rubber might crack. I will change it out after removing interior trim. You will not have to do this again when you need to change rear shocks.
      07-23-2013, 07:24 PM   #17
drbvac
drbvac's Avatar
Drives: 2006 BMW M COUPE
I had a clunk from the right rear when going over certain bumps at certain speeds at a set angle and drove me nuts.
My mechanic put it up on a hoist and with a pry bar pushed and moved all the bushings on that side and it ended up being the inside nylon bushing on one of the suspension arms - little play or hardening up and - clunk -clunk -
I found that rubber / bushings etc will degrade or harden over time regardless of mileage and then they will make noise.
Replace with OEM or new silicone bushings and - no noise.
I would check them before getting new shocks or mounts
2006 M COUPE - 380 total production, 1 of 40Imola Red produced for NA , ESS 455 Supercharger, Speedhut Gauges, VPM CLS wheels, 19" Hancooks, Stromung Exhaust, Carbon fibre accessories and black and white badging,
      07-23-2013, 07:37 PM   #18
Shipkiller
Shipkiller's Avatar
Drives: Me
The suspension bushings degrade over time not mileage. This is just a BMW thing. It happens to all BMW's. Also a broken spring can cause this.
May things can cause this. There is an SIB about the rear anti-roll bar mounting bolts, but I do not have it.
The SIB from BMW talks about the clunking or grinding noise from the diff: http://www.shipkiller.com/SI%20B%203...Jan%202009.pdf
      07-25-2013, 07:16 AM   #19
Kim Schwartz
Drives: 128i
This is a very good description of what I experience. This sounds like a place to start since there seem to be a few possibilities. Thanks everybody for your suggestions.
      07-25-2013, 03:38 PM   #20
drbvac
drbvac's Avatar
It was # 13
