08-05-2013, 06:01 AM | #1 |
Rep 34
LS2 Z4 Build- Diff Question
Has any one got an idea on how strong the diff in the 3.0 E86 is, is LSD 4.11
Looking at all options for this build , fabrication is not a problem but less is better |
08-05-2013, 07:16 AM | #2 |
#buildnotbought
10855
Rep 4,893
The e86 3.0si hasn't got an LSD stock. It's an open diff and the ratio is 1:3.46 (manual) or 1:3.64 (auto)
08-05-2013, 02:09 PM | #4 |
#buildnotbought
10855
Rep 4,893
If it isn't a stock diff, and you dont tell the maufacturer and type, how can we possibly say how strong the diff is?
08-05-2013, 04:00 PM | #6 | |
#buildnotbought
10855
Rep 4,893
I know about quaife.......
I quote from quaife: Quote:
Your unknown gearset can handle unknown HP
08-07-2013, 08:01 AM | #9 |
#buildnotbought
10855
Rep 4,893
A 188mm quaife can handle a lot more than 400hp mate.....
Lots and lots of examples of guys driving around with quaifes and (a lot) more than 400hp. So I don't know where you got your information from, but real life examples prove that it's not correct.
08-08-2013, 12:15 AM | #10 |
Rep 34
Quaife is not 188mm that is the ring size, this is the part that fails(most of the time ) I rang and spoke to 2 BMW Motorsport companies both of whom said the 188mm would not be sufficient for 500rwhp.
Both recommended swapping it for the E46 M3 lsd. no point in cutting corners for a couple of grand |
08-08-2013, 08:25 AM | #11 |
Rep 12,565
There's another fellow here doing a LS swap too, you should reach out to him because he's gotten petty far in his build. His name is v8z4 though he's more active on Bimmeforums.
08-08-2013, 02:03 PM | #12 |
Rep 34
Thanks I might see how he is going because the amount of fabrication to fit it in with the right weight balance is a huge job. For anyone chasing diff gears I just sourced 4.1 ratio gear set from Bobby Rahal for $800+shipping best price I have seen anywhere, speak to David.
08-08-2013, 02:52 PM | #13 |
Rep 2,782
Interested in selling the current unit ??
