12-09-2015, 04:33 PM | #1 |
BMW obsessed
9587
Rep 10,877
IND | Eventuri E85/E86 Z4M S54 Carbon Fiber Intake System
Our team at IND is proud to welcome Eventuri to our growing family of brands. Eventuri is brought to us by a team of engineers with over a decade of automotive engineering and design experience and genuine interest in the automotive aftermarket performance industry. Their intakes represent a detail oriented and comprehensive approach to optimizing airflow – leading the industry in both fit, finish, and sound engineering that outperforms factory original equipment. Each Eventuri system is designed to create a large captive volume, extremely smooth transitions, and CFD-optimized airflow. The majority of aftermarket intakes utilize a combination of a filter, heat shielding element, and tubing. With this design, air navigates through the the large base diameter of the filter to the smaller diameter of the inlet pipe in a relatively short distance. The bottleneck design has been found to be detrimental as air turbulence and dead spots create loss of low to mid-range torque. Eventuri’s unconventional inverted filter design efficiently maximizes airflow while maintaining an aesthetically pleasing design. Curved scoops channel fresh air into the funnel shaped housing, which then smoothly transitions through equally sized tubing. This creates a true velocity effect that is not inhibited by abrupt geometry changes – thus resulting in more power and sharper throttle response. Eventuri E85/E86 Z4M S54 Carbon Fiber Intake System $870.00 Please contact IND by phone or email for more information or to place your order. 866.963.4520 | info@ind-distribution.com The Eventuri E85/E86 Z4M S54 Carbon Fiber Intake System may be viewed here in our online store: http://ind-distribution.com/ind/bran...-intake-system
