      09-14-2012, 06:55 PM   #1
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
OEM Ipod adapter 65110392130
SOLD
      09-15-2012, 03:53 AM   #2
Beedub
tom does this replace the cd changer??? can you explain alittle more please for the non techno peeps out their?? like me!
easy install??? works with iphone??
      09-15-2012, 11:13 AM   #3
ZStig
279
it should work fine with the iphone. I'm gonna check, I might have the 12v-5v adapter you would need. Then it would play and charge your iphone.
You're limited to 5 playlists, which is enough for me. Well, you'd create 5 playlists called "BMW1, BMW2..." that would be selectable quickly by the numbers on the radio, but you can still have any number of playlists after that that you could listed to by "play all".
http://www.zpost.com/forums/showthre...highlight=ipod
as for the cd changer, my car never came with one, but I think it just uses the cd changer cable that plugs into the radio. Mine was already pre-wired, so I just changed out the unit for a new one. Then I realized my old one is fine. I believe these are the correct instructions, the hardest part for me was routing the cable from the glovebox since I didn't use any tools except jammed my hands in tight places to grab it
http://www.bimmerfest.com/forums/sho...d.php?t=297113
If you have any more questions hit me back. To compare, I had the Dice kit and it would often cut out. The Intravee kit is expensive as fuck. The only issue I had with this kit is that the unit-ipod cable wasn't installed properly (was rubbing on hard edges) and eventually got physically damaged.
      09-22-2012, 11:18 AM   #4
ZStig
279
$80
      09-25-2012, 09:21 PM   #5
ZStig
279
bump, lowered to $65. Need this gone
      09-26-2012, 08:19 AM   #6
fdagen
Drives: 2006 Z4M Roadster
I'll take it. Did you find the iPhone adapter?
      09-26-2012, 05:24 PM   #7
ZStig
279
U're lucky. I got someone else that wants it, but you get first dibs at it since you said you'll take it first. I found the 12v-5v adapter, it cost $20, but I can throw it in for an additional $5. Figure shipping will be about ~$5 by priority mail
      11-17-2012, 07:04 AM   #8
batfly23
Drives: BMW X5 3.0D
Ipod Interface
Hi, i'm interested to purchasing the kit if it is still available
      11-17-2012, 05:13 PM   #9
ZStig
279
sorry, it has sold a long time ago. I've updated the post
      11-21-2012, 05:13 AM   #10
batfly23
Drives: BMW X5 3.0D
Kit Ipod
Ok, anyway thanks a lot.
