      03-02-2011, 01:04 PM   #45
itsregie
Drives: 2006 Z4 Roadster
Sounds good, I've been waiting for this! Is there a possibility you can post the codings that you are officially able to do? If so we can PM you what exactly we want done and get a pricing quote.
      03-02-2011, 02:03 PM   #46
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
I want in on this =]
Quote and instructions please. Do I need to send you my ECU?
      03-02-2011, 02:20 PM   #47
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
LCM not ECU
      03-02-2011, 02:23 PM   #48
mfanatic325
///M-fanatic
Taiwan
193
Ohh icic. Could someone please link me to a DIY on finding and removing the LCM? =]
      03-02-2011, 02:44 PM   #49
Shipkiller
Shipkiller's Avatar
Drives: Me
The LCM (lighting control module) is your light switch.
It is not just a switch but a whole assembly. About 9" in depth...
Pull the trim piece off and remove the screw, pull out the assembly... I would have your battery discontented before you disconnect the connector.
The LCM and ECU both contain the vehicles odometer reading. If one gets out of sync with the other a dot is seen next to the odometer readout. It's an anti-tamper measure. It takes a GT1 to sync them up if one is replaced.
      03-02-2011, 04:09 PM   #50
mfanatic325
///M-fanatic
Taiwan
193
Cool thanks for the info. I'll take a look and see if I feel confident enough to take apart the trimming and such without breaking everything LOL..
Any advice/hints/tips/pointers? A DIY would be great, as I'm more of a visual learner =P
      03-02-2011, 09:12 PM   #51
johanness
Drives: 2008 Z4MC
So... I assume if I'm going to get my LCM out and ship it, I should NOT be driving the car? Like at all... correct?
I was told I only needed to send in the LCM and not the ECU. Is this right also?
      03-02-2011, 09:26 PM   #52
mfanatic325
///M-fanatic
Taiwan
193
As far as I know, that is all correct
      03-03-2011, 01:01 AM   #53
pingpong
Drives: BMW
To get the remote roof close thing, is that an LCM thing as well, or a different component?
      03-03-2011, 01:06 AM   #54
mfanatic325
///M-fanatic
Taiwan
193
According to the info in this thread, he can also get this done for you. If I'm not mistaken =]
      03-16-2011, 09:49 AM   #55
3002 tii
3002 tii's Avatar
2286
Jamie - let me know if you're taking appointments yet... =D
Follow for latest mods
      03-16-2011, 10:02 AM   #56
Starscream
Starscream's Avatar
Will do,
Been side tracked this past week,
Imola Red Roadster
      03-21-2011, 01:28 AM   #57
mfanatic325
///M-fanatic
Taiwan
193
So....whatever happened to this? I haven't yet tried to take my LCM unit out, but figure it's for the better; until I schedule a coding appointment
      03-28-2011, 10:04 PM   #58
vtnard
Drives: 2011 335i
I tracked down the modules and language that needs to be modifed for comfort close (ie close with key) and to disable headlamps wash...GM5 module....Just coded up my buddies e86...And read a bunch of modules....Luckily some of the language is very similiar to the e90s once you read the .trc file.
      03-28-2011, 10:54 PM   #59
johanness
Drives: 2008 Z4MC
Does this mean that we're getting close to this happening?
      03-29-2011, 10:22 AM   #60
3002 tii
3002 tii's Avatar
2286
Weird, I had 2 locals who happened to have the software but neither could get it going on my E86, kept getting "faulty VIN" or something like that, but it basically never connected.
      03-29-2011, 03:10 PM   #61
vtnard
Drives: 2011 335i
Did they get the updated Daten files....I've got the orginial V39 and V40....Also they need the adapater that is being sent now with the cable.....Pin 8 needs to be there for the e85.....The cable comes without it.... I still cant acess all the modules, but GM5 is one you would want to play with. Heres the GM5.TRC file
FSW_PSW_GM5.txt
      04-12-2011, 05:20 AM   #62
alvinli217
alvinli217's Avatar
Drives: Imola RED dIrTy Z4MR - SOLD
any update man? leaving town soon so it's a good time for me to send it out to you.
RPI scoop|BMC drop in filter|EAS V1 aluminum mount|ZHP shiftknob|RHO plate holder|matte black grill|LED interior & license plate light|RE SSK|RE tranny mount|UUC engine mount|Bavarian CDV|clutch stop|18" Forgestar CF5 GOLD|RPI exhaust|H&R coilovers| RE RSM|
coming soon: aFe intake|tune|secondary cat delete|
      05-11-2013, 09:54 AM   #63
3002 tii
3002 tii's Avatar
2286
Bump for update, simply looking for the one line that disables ALL 3 amber bulbs or the 3 individual coding lines needed to disable each individual bulb. It's the inner most bulb closest to the grills that we are having trouble identifying.
      05-11-2013, 10:19 AM   #64
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
Wow just found this thread. Awesome work Starscream. I'd be interested in this!
      05-15-2013, 12:34 AM   #65
JeffchaPz
JeffchaPz's Avatar
17
Drives: 2007 Z4M
Gents, PA Soft allows you to do all of this for $30 bucks or less if you do a little research.
I was able to turn off my angel eyes off and allowed me to use one or both of the amber lights to come on every time I would start the car, or if you select euro - it will turn on the head lights as driving lights and you can turn off the others if you want. I ended up removing the amber bulb closer to the front wheels.... I think 2 ambers are enough at night. search my prof pics and post... you'll see what I mean.
Good luck.
      05-15-2013, 12:38 AM   #66
JeffchaPz
JeffchaPz's Avatar
17
Drives: 2007 Z4M
Oh, I ended up changing the voice in my navi to a male voice with British accent and turning on my clown nose. I also enabled my turn signals only when I lock the lock. OH I enabled the option to open and close the top with the unlock and lock button..... ba bye!
PA soft... get it!
