07-17-2007, 05:32 PM | #23 |
My favorite sign.
169
Rep 4,333
I'm not sure I follow. You're saying that the gap between the inside edge of the rim and where the tire sits is wider than stock, so that makes up for the 1/4 inch of radius he lost with the low AR tires?
07-18-2007, 01:58 PM | #24 |
Rep 821
Correct me if I'm wrong, but isn't the entire purpose (of the particular wheel sizes that Ron gave us) to preserve the overall stock diameter, even with the new wheels?
They both come out to about ~22.5 inches or so. Or close enough. The way I look at it, I guess, is that yeah, the M6 rims are an inch bigger than stock, but the tire sizes you would buy for it are an inch shorter, therefore negating any significant difference except sidewall compliancy. I would imagine the reason that Mako's wheels look fine without a drop, is because the stock wheels and tires also look fine without a drop, and Mako's overall diameter is the same. He simply has more metal surface area to keep things shiny and interesting.
Guy #1: "Hanz, I know zee window switches have always been next to zee shifter in zee 3er cars, but I think ve should move them to zee door!"
Guy #2: "But zee doors are already designed and ve do not have time to re-design them!" Guy #1: "Just make it verk or you vill be verking over at VW!" |
07-18-2007, 02:04 PM | #25 | |
Rep 821
No, I think the reason a car looks like a 4x4 when you upsize the rims, is because upgrading from 16's/17's to 19's without the appropriate tires will, in many cases, actually LIFT the car an inch or two, because with the larger overall diameter comes a larger distance between the axle and the ground.
07-18-2007, 02:07 PM | #26 | |
Rep 821
It would involve lowering the springs etc to bring the car closer to the wheels instead.
07-18-2007, 02:36 PM | #27 | ||
Rep 1,269
Tire sizes & tire overall diameters: Stock Z4M tires: 225/45/18 - 659.63 mm 255/40/18 - 661.16 mm 235/35/19 - 646.93 mm 265/30/19 - 641.35mm 245/35/19 - 654.05 mm 275/30/19 - 647.44 mm If you go with either 235/265, or 245/275, you're decreasing the overall tire diameters, hence why the car now sits closer to the ground, and why the wheel gap is now bigger. Quote:
2019 Porsche 911 4 GTS
2016 BMW M3 2008 BMW Z4M coupe Last edited by GP20; 07-18-2007 at 04:57 PM.. |
07-18-2007, 02:46 PM | #28 | |
Rep 1,269
07-18-2007, 03:21 PM | #29 |
Booyakasha!
40
Rep 413
Drives: '13 Mini Cooper S Coupe'
'08 M Coupe--AW/IR--SOLD!--My M Coupe Obsession
'13 Mini Cooper S Coupe - My Maui Mobile '13 Mini Cooper S Paceman- My Maui 'Stuff Hauler' |
07-19-2007, 12:50 AM | #30 | |
Rep 821
Correct me if I'm wrong. 18 inch wheel + 3.986 (225mm*0.45) inch tire = 21.986 inches diameter 18 inch wheel + 4.015 (255mm*0.40) inch tire = 22.015 inches diameter 19 inch wheel + 3.375 (245mm*0.35) inch tire = 22.375 inches diameter 19 inch wheel + 3.248 (275mm*0.30) inch tire = 22.248 inches diameter It seems to me that there's some error in your numerical work, because a 650mm diameter is more than 25 inches across, and I would think that size is a bit large to fit in the wheel well of any Zed, M or otherwise.
07-19-2007, 01:20 AM | #31 | |
Rep 126
http://www.e90post.com/forums/forumdisplay.php?f=12 |
07-19-2007, 02:14 AM | #33 | |
Rep 1,269
To get the height of the side-wall, you took 225 (tire width) and timed it by the aspect ratio 45% or 0.45 and eventually got 3.986"; this part you did correctly. Now this is where you did the calculations wrong - you then proceeded to add the full length of the rim and only 1 end of the side-walls of a tire (3.986") together. You forgot about the opposite end of the side walls. To get the diameter of the wheel, the correction calculation would be: (diameter of the rim) + (tire-width x aspect ratio) x 2 or ( (radius of the rim) + (tire-width x aspect ratio) ) x 2
2016 BMW M3 2008 BMW Z4M coupe Last edited by GP20; 07-19-2007 at 02:58 AM.. |
07-19-2007, 12:00 PM | #34 |
58
Rep 2,201
Drives: 996TT/ae86
Heh, I need to go chop that grapevine As of now, no truth about it coming out in the future. We talked about it at a meeting but that's it, just talk, I wouldn't expect anything for awhile if it was to happen.
07-19-2007, 01:45 PM | #35 | |
Rep 821
Haha, my mistake. Thanks for the clarification.
08-23-2007, 03:26 PM | #37 |
Booyakasha!
40
Rep 413
Wheel weights with tires:
Stock 18" wheel + tire: 50lbs (F), 55.5lbs (R) Miro M6 19" wheel + tire: 49lbs (F), 54lbs (R) Not bad!!!! --Chad
09-19-2007, 09:57 PM | #38 |
Rep 456
How "bad" do these look in 18's?
I'm curious as I just picked up a Z4 and I'll only have it till MAR08. What other cars (335/328? possibly) will 19/ w/ the Z4 offset go onto?
2008 E92 335i Space Grey Coral Rep SOLD
2011 Cadillac CTS-V CURRENT Juan Barnett, Founder, dcautogeek.com T: @DCAutoGeek juan@dcautogeek.com |
09-20-2007, 07:07 PM | #39 | |
58
Rep 2,201
Drives: 996TT/ae86
They don't look necessarly bad in 18, its just that I think most people prefer going to the bigger size like the 19's if they are going to go and get some wheels and tires. The offsets of the Z4 are high offsets so in 19, you are looking at 19x 8.5 ET35 and 19x9.5 ET40, If it was an MZ4 the rear would be a 19x9.5 ET20. |
10-02-2007, 09:47 AM | #41 |
Rep 4,365
That is because you have no style... or Zed
10-02-2007, 02:50 PM | #42 |
Rep 21
dude, let your eyes go out of focus... it's a big flower! now do you get it?
not really my thing either, but they do look like they'd show less brake dust with that dark interior and be fairly easy to clean. if they could be had in the 18 to 20lb range i'd like the look a little more |
10-03-2007, 01:25 AM | #43 |
Wang D.D.S.
185
Rep 7,057
M6 wheels look perfect on the Z's, especially after a drop!!!
10-08-2007, 05:29 PM | #44 | |
58
Rep 2,201
Drives: 996TT/ae86
