      11-21-2012, 02:13 PM   #1
jcnpa
Drives: 06 red Z4MR
alarm siren
I have looked but do not see anywhere where it states to put the siren in a Z4MR. Can someone tell me if it is the same as the I or SI and goes in the rear passenger bumper area? Or is it the same as a Z4MC and it goes under the car in the back after removal of the rear panel.
Thanks in advance for any info.
      11-21-2012, 03:04 PM   #2
SD ///M4
///Multiple
SD ///M4's Avatar
Edited to remove incorrect answer and avoid any possible future confusion.
      11-21-2012, 03:13 PM   #3
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
The M is different, it goes under the rear diffuser.
http://www.bimmerfest.com/forums/sho...53&postcount=9
      11-21-2012, 03:43 PM   #4
SD ///M4
///Multiple
SD ///M4's Avatar
Ok, since we're talking about the rear diffuser, does anybody know the p/n for the two 12mm nuts shown in this pic. When I replaced the mufflers I took off the diffuser and discovered that these two nuts were missing.
I looked on realoem.com and thought it was p/n 51711958025, plastic nut, #4 in this diagram, so I went to the dealer and they gave me two plastic nuts that aren't threaded and have a much wider built-in washer base. I haven't tried to put them on and I'm not sure that the washer base will fit into the recess, so I don't think that this is the correct part (click diagram for realoem link):
Hmmm, looking at this diagram again, I think that it's actually p/n 12421438388, cap nut, #30 in the above diagram. Can anyone confirm?
      11-21-2012, 04:26 PM   #5
jcnpa
Drives: 06 red Z4MR
Thanks inTgr8r, appears it is the same procedure as the Z4MC.
      11-21-2012, 09:00 PM   #6
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^ yes M coupe & roadie are the same.
