12-13-2010, 05:18 PM | #155 |
Rep 1,739
Drives: 2008 Z4MC
Why would a 6.1 Hemi satisfy me more than an award-winning S54 which I'm currently loving? Regardless, the points been made.
12-13-2010, 05:40 PM | #156 |
1821
Rep 5,337
The OTHER half of the equation...
To me, the signs that ///M GmbH has sold out is that cars like the 850CSi, which came with a reworked body panels, ///M engine (S70B56, unique "S" engine made by Motorsports only for this car, at the time), ///M tuned suspension AND only comes as a manual for an 8 series. Yet it did not receive the ///M badge. The mighty Z8 with the S62 engine, all ///M suspension wizardry, manual only, did not receive the ///M designation. The LeMans X5, another car to receive an "S" only engine (same S70 as above though), with all the ///M suspension tuning AND new body panels, did not get an ///M badge simply because it's AWD. There were so many more BMW vehicles that far more deserving for an ///M badge but didn't. Yet the 1M Coupe, with a run of the mill N54 engine, gets one after all the great cars before it got shafted. That is the ONLY thing I have a problem with.
12-13-2010, 06:45 PM | #157 | |
Rep 11,667
It all comes down to marketing these days. They know they'll sell X% more cars just by adding a fifty-cent M badge.
12-14-2010, 12:38 AM | #158 |
Rep 2,782
The biggest problem is that it's an M car you can't drive on the track... that is unless they have worked out the cooling issues of the N54. M is supposed to stand for "Motorsport," and you won't win very many races in limp mode.
We can all agree that the S54 was a maxed-out naturally aspirated I-6. The stroke could not be increased because of the piston speed. The bore could not be increased because the cylinder spacing was already so tight the block had to be made of iron, and lengthening a heavy iron block I-6 would seriously affect the car's handling. The S54 is a great engine with plenty of power, but it needs more power in the 1M to remain competitive. It is physically impossible to build a streetable NA I-6 with significantly more power that will last 100k+ miles without lengthening the block and increasing displacement. It was a combination of everything that killed the S54. Weight of the car vs. performance requirements, age/marketing (buyers want something new and improved, and the S54 couldn't be "improved"), emissions, etc. BMWs have gotten so heavy that they can't use a high-revving (low torque) engine to get their cars off the line. Ideally the M division would have developed a new turbo engine for this car that can perform on the race track. Perhaps a low compression S54 running mild boost would have been acceptable. Next would be the S65. I believe the reason they didn't use the S65 is because it doesn't flow with their new direction more so than fears of the 1M toppling the M3. Otherwise, they could stroke out the M3's S65 and call it an S66 to keep it a tick faster. The N54 is last in my book. Its track record is terrible, it's off the shelf and not a special engine built specifically by the M division (reducing brand credibility), and it has less excitement than any naturally aspirated S engine. It's good for posting numbers for Car and Driver and daily driving. It will have none of the thrill of a screaming NA engine being driven to its limit on the track. |
12-14-2010, 12:59 AM | #159 |
1M advocate
214
Rep 878
They have improved the oil cooling system for the 1m over the 135i... it really shouldn't have a major problem handling normal track duty.
2012 BMW S1000RR
2011 BMW M3 |
12-14-2010, 12:03 PM | #160 | |
1821
Rep 5,337
First, on the N54 there's a cooling exchanger between the oil and coolant, and both oil can coolant temp will trigger limp mode. I've taken some unofficial sample of limp modes by local region instructors and club racers with this particular engine that have been logging their temperature for both coolant and oil, and it appears that half the time limp mode is triggered by coolant. It makes sense, since the N54, once shut down, uses the coolant to cool off the turbo. So on a 25 minute per session day, with up to 4 sessions, potentially that heat does not evacuate the system and coolant will run hot even after you come off the track. So even if you upgrade the oil cooling capacity, you are not addressing the inherent problem of a hot coolant due to using it to cool down the turbo AFTER shut-down. Second, the architecture of the inline 6 is inherently problematic for cooling the last two cylinders. While in a naturally aspirated state, the lack of cooling in cylinder 5 and 6 does not rear its ugly head, you put two turbos on a engine designed to run hotter than engines from the last few generations? That inherent cooling issues have no solutions. You can artificially bump the water flow rate, but then you're still operating with bank 5 & 6 covered under the bulk head with little to no access to vent that heat. There's a reason why no manufacturer has tried to turbocharge an aluminum inline 6, and only two turbo-charged inline 6 has ever had any sort of success in motorsports. It's far more common to see turbo'ed I-4, V-6, and V-8. Third, we've seen plenty of attempts at trying to keep this N54 engine running cool enough to survive a couple of 25 minute sessions. I haven't seen any evidence of anyone actually having any sort of real success in this regards. There are a few N54 drivers claiming to have fixed the problem with larger oil coolers, and yet there are just as many who reported to continue to have limp issues with the same fix. I will reserve judgement, but if I'm a betting man, I'd put money against BMW at having this issue solved at this point.
12-14-2010, 12:50 PM | #161 |
704
Pokey, great concise summary....
Hack, that's a pretty compelling argument. Of course time will tell, but I would not be willing to bet against your assessment. I will reserve judgement as well--the proof will be in the pudding so to speak, but since we're speculating anyway.... The Hack's post raises some interesting questions. Assuming he is right about the inherent design issues with the I6 design and turbos (and I believe he is), it sounds like the ///M division is going to come out with:
None of the "solutions" are likely to sit well with the faithful (aside from the I4 possibly, since it can be played as the E30 reborn, yada yada), although I'm sure some would be convinced by other designs if the performance/dynamics were there and track requirements fullfilled. I for one would not bitch about a lower weight car with the great handling, brakes, engine dynamics, and cooling capacity. |
12-14-2010, 01:23 PM | #162 | |
Rep 171
I also wouldn't be surprised to see a dry sump system in place (press releases say the transmission is dry sump). Dry sump systems for turbos greatly help in terms of short term and long term reliability since it reduces the distance the oil has to travel and helps to prevent heatsink on start up and shutdown. I wouldn't count BMW out in this regard. |
12-14-2010, 01:40 PM | #163 | |
Rep 576
Drives: Interlagos Z4 M Coupe
12-14-2010, 01:47 PM | #164 |
1821
Rep 5,337
Well...To call the S14 just a run of the mill BMW engine with a re-worked cam would be to call the S54 just a normal M50 block with a little bit of work up top.
The S14 was "derived" form the M10 block, uses the same block (not dissimilar to the S54 which was derived from the M50 block since it was the last of the iron blocked BMW engines) but has completely re-worked valve-train to allow it to rev to stratospheric heights and also 4 individual throttle bodies. I believe the only thing it shared with the M10, is the block.
12-14-2010, 02:51 PM | #165 | |
Rep 576
I say props to BMW for not playing the bhp game with Audi and the ttrs. Peak-power issues aside, in my opinion, the addition of an M badge was important because it showed that M division is catering to an almost Everyman who is into tracking there car. I think bc the power gains are so small over the 135 that wannabes like mane who own m3s for the 414hp v8 will stay away. Me likes this.
WE ARE!!!!!!
12-14-2010, 03:30 PM | #166 | |
Rep 174
I htink that if anything, the M badge will increasingly attract wannabe's. They just go for the badge, and the price. |
12-14-2010, 03:39 PM | #167 | |
1M advocate
214
Rep 878
and the M badge has attracted wannabe's since the e30 m3 days. don't act like it's a new thing.
2012 BMW S1000RR
2011 BMW M3 |
12-14-2010, 03:47 PM | #168 |
Rep 174
No, certainly not new. Hell, the venerable Z4 M was so very popular with the wannabe's because it has "almost as many M badges as it has exhausts".
12-14-2010, 03:52 PM | #169 | |
1821
Rep 5,337
Cooling issues in the E36 and E46 with the aluminum radiator and plastic necks were well documented. Cooling issues in the S52 and S54 for race use were well documented too, although not nearly to the extent that it plagues the N5X. So before we jump to say that BMW engineers know what they're doing...Remember, BMW engineering is now driven more by profit than anything else. I think, especially with the recent direction BMW is headed in, all I can say at this point is I will await judgement on the 1M's actual track worthiness. If it does indeed address all the overheating issues that the N54 suffers from, it will be a big plus and certainly a step in the right direction for me from BMW. But that begs the question. Why hasn't there been an attempt at resolving this throughout the N54's lifecycle?
12-14-2010, 03:59 PM | #170 |
///M'n it Up
17
Rep 344
Just in case anyone missed it... here's a 360 view of the car
http://www.bmw.com/com/en/newvehicle...isualizer.html |
12-14-2010, 04:26 PM | #171 | |
1M advocate
214
Rep 878
Neither of those issues were as abundant as the limp mode n54, and I assume given the severity and occurring rate of the problem the M engineers will have addressed and solved it with the 1m.
2012 BMW S1000RR
2011 BMW M3 |
12-14-2010, 04:37 PM | #172 | ||
704
That's a pretty strong and definitive statement, and I hope you're correct. Personally, I think it's a bit early to know one way or the other....Anything other than actual use at various tracks under various conditions by various drivers isn't, from my perspective, a valid set of tests. It might be fine, it might not be--I think we need to wait and see. We (including me) are all speculating at this point. Quote:
I also agree that BMW engineering is driven by profit, just as any car company. And in the quest to provide good and frugal engineering (and due to bean counters) sometimes this leads to cutting corners. Example: IIRC early N54 cars didn't even have an oil cooler and that was an issue off the track; cars were retrofitted with oil coolers and subsequent iterations of the platform all had coolers. While there have been improvements (hadn't followed this in the past year or more) such as supplemental cooling capacity on the IS models (or upgrade package) those provide limited improvements. And it's not just "limp mode" overheating that's an issue--as heat soak occurs the intercooler, oil, coolant, cannot keep up resulting in the ECU pulling boost and timing and hence power drops--all of that happens before limp. Sure, you can use things such as aftermarket meth, or water sprayers (ala some Japanese intercooler tricks) to try and keep the intercooler working efficiently, but they're only good up to a point. The ECU has many things built in to hardware/software to protect the engine and allow it to keep running--and those essential safety features if employed (due to heat) would certainly affect the car's track ability unless some really cool (no pun intended) measures have been employed to address them. The point here is that a turbo car by its very nature is a more complicated beast to keep operating at full tilt under hard and hot conditions. Not that the folks at BMW aren't smart, but these things start becoming very costly to implement. I honestly and sincerely hope the cooling issues have been addressed. Maybe they've found ways to be exceptionally cleaver and frugal...time will tell. Last edited by Finnegan; 12-14-2010 at 04:46 PM.. |
12-14-2010, 04:53 PM | #173 | |
Rep 576
Fact is, no one really knows what changes have been made, so its all speculation here. And yeah poseurs buy everything, but are more inclined to buy the fast cars when theyre laced with luxury. The base carrera was not a poseur car before it became luxurious. Porsches were snap oversteer-prone and poseurs seemed to just crashed. Now even the GT2RS can be DD. Same goes with the m3. Once the e46 got luxurious, the M3 became a fast car that requires no DD sacrifices. Sacrifices that the Zed crowd doesnt mind making. Hence our overwhelming percentages of track-driven cars. |
12-14-2010, 05:55 PM | #174 | |
704
So, concerns about "heat" may be completely blown away by reality. Which would be cool (pun intended). It's going to be fun to see what these cars do IRL. Surprises can be fun! (And I wouldn't mind being pleasantly surprised--in which case picking up a nice used one after the initial depreciation might be something to consider....) |
12-14-2010, 06:06 PM | #175 |
1821
Rep 5,337
I'll say this. I'm not often wrong, and when I am, I rarely ever admit it. But this is a case where I am GLAD to have been proven wrong. At least, in some small way, BMW has made a concerted effort in reducing weight of their consumer car(s) for the very first time.
Let's hope I'm proven wrong about the engine and it's propensity to go erectile disfunction on the track. It's another case where I'd be glad to be wrong.
12-14-2010, 06:24 PM | #176 | |
704
I hope I'm wrong about heat too. BTW, the ED comment just killed me! |
