11-25-2017, 11:57 AM | #1 |
Rep 6
2003 won't start
Hi folks. A problem has come up with my 2003 Z4 Ragtop. My ignition key locks/unlocks the car, I turn the ignition and all the dashboard lights come on as normal, when I turn the key to start, you can hear stuff "initialising," but there is nothing not even a click. It will bump start from cold within about 6 feet on a gentle slope, even in these really cold conditions. I took it for a 50 mile run and it started ok, immediately after I parked up. 1 hour later, it won't start again. Headlamps etc. are strong even without engine running. Immobiliser problem?
Sorry if this has been answered before, but I've trawled through and couldn't find anything. Stevie Last edited by StevieS; 11-25-2017 at 12:08 PM.. |
11-25-2017, 04:20 PM | #4 |
Rep 4,057
I’ve seen other folks post here that their car does all kinds of odd things when the battery is on its way out. That may be a potential cause.
11-26-2017, 06:03 AM | #5 |
Rep 6
Have stuck a meter on it. From cold it reads 12.2v Car won't start. Bump started, then showing 14.4v. (14.6v when revved.) Turned off, then on, won't start. Battery is BMW 12v 70ah. 570CCA. Tell tale is black, this says the battery isn't charging. If it was yellow, it would indicate a faulty battery.
New battery then? |
11-26-2017, 10:39 AM | #7 | |
Rep 1,794
Drives: E86 3.0si
If the battery is 12.5 = 85% charged 12.4 = 65% 12.3 = 50% 12.2 = 35% 12.1 = drained Testing with a load tester (many parts stores will test batteries) will definitively determine if the battery is bad. Load testers: |
11-26-2017, 10:56 AM | #8 |
Rep 758
Have someone try to start the car while you measure the battery voltage. I'm guessing you'll see it drop to 5-6V (or even lower). If so then the battery has a cell that's going bad, but hasn't completely shorted yet.
Top Down 365
11-26-2017, 01:40 PM | #9 | |
Rep 932
MinneapolisJeff8.00 |
11-30-2017, 01:40 PM | #11 |
Rep 6
New battery, fully charged hasn't fixed it. One thing I've noticed, is that the immobiliser light seems to be flashing more than normal, although I could be imagining that.
Getting home in the dark means I can't really mess around. till Saturday. As before, the key fob locks/unlocks the doors and boot. When I sit in the car and turn the ignition to on, all the lights come on. When I turn it to the start position, there is no loud click, just a faint one from the right hand side of the dash after all the initial noises. Engine is not attempting to turn at all, no starter motor noises. I've read about hitting it with a hammer and making sure the terminals are clean, so will try that on Saturday. (Once I find it.) |
11-30-2017, 03:48 PM | #12 |
Rep 326
Maybe a dead starter? I just replaced mine in September. Alot of similar symptoms, except my starter would single click and do nothing else.
the stable:
2003 BMW Z4 3.0i 2020 Mitsubishi Outlander SE 2021 Jeep Gladiator Rubicon |
11-30-2017, 05:44 PM | #13 |
Rep 305
Had the same issue with my '06. Turned out to be a bad ignition switch. Picked up a replacement at the local autoparts store and took me about 10 minutes to replace.
2006 Z4 coupe - with HOMELINK!
1966 Mustang GT fastback (too many mods to list) 2015 335i GT 2014 981 Cayman S manual |
12-01-2017, 12:24 PM | #14 |
Rep 1,794
Drives: E86 3.0si
Don't overlook the clutch interlock switch. If clutch pedal doesn't depress it...no starter engagement.
12-01-2017, 05:51 PM | #15 | |
Rep 156
12-06-2017, 01:14 PM | #16 |
Rep 6
Hi folks. It turned out to be the starter motor. Was an easy enough job with the help of the excellent post on here regards that job. I took it off the car, tested it as per a Youtube I watched, then put it back on. Ordered a new one and replaced it tonight in the works car park. Thanks to all for your advice. Much appreciated.
