      07-20-2012, 09:26 AM   #23
3002 tii
3002 tii's Avatar
2289
Originally Posted by STIHLBOLTS View Post
Get Mike's Decals for the markers, they are still reflective and you can always take them back off later.
I just put them on my car to finish off my look.
Mike or Dan's?
Mike's - got a link?
Follow for latest mods
      07-20-2012, 03:48 PM   #24
STIHLBOLTS
STIHLBOLTS's Avatar
Drives: 2013 335is
2020 Z4 M4.0i  [5.00]
^-Fixed above.
2013 335is E93
2018 X5 35d
BMWCCA / ZSCCA Member
      07-30-2012, 12:34 PM   #25
JeffchaPz
JeffchaPz's Avatar
17
Drives: 2007 Z4M
OP:
Sweet car... do mind sharing how and how much your car is lowered?
      07-30-2012, 12:44 PM   #26
BIMMERGUY91
Drives: 2014 335I M Sport
Originally Posted by Rated M Roadster View Post
Thanks guys!
I'm running H&R coilovers all the way down. I'll raise it back up a bit for the next autox. Wheel and tire specs are listed above.
Are you sure they are all the way down? Mine arent all the way down (close to it) and my car looks like it sits a little lower than yours. What are your camber settings btw? Wondering how much camber its taking to clear that 9.5" up front. Looks great BTW!
Edit: Just saw you are running around -2.5 degrees up front. Looks great!
2014 335i M Sport
2010 328i M Sport
2007 Z4MC #1019/1815 (Sold)
1997 M3 (Sold)
1991 325i
      07-30-2012, 04:48 PM   #27
Rated M Roadster
Rated M Roadster's Avatar
162
Drives: F10 M5, i3, Z4M
Am I sure? I don't remember installing my suspension with my eyes closed, so yes I'm sure.
But thanks.
      07-30-2012, 05:45 PM   #28
phoenixbmwlife
phoenixbmwlife's Avatar
Drives: M235i & G30 540i
2014 BMW/M235i  [0.00]
Car looks great with the new wheels!
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta
https://www.instagram.com/bmwm_life_/
https://www.instagram.com/autogiftua/
https://www.instagram.com/phoenixbmwlife/
      08-03-2012, 01:42 PM   #29
itdnwiwbp
Drives: 330iZHP
Rated M, are you running any spacers? If not, have you had any rubbing issues? I only ask because I see that Apex recommends spacers for that size setup in the front. Thanks.
      08-03-2012, 02:18 PM   #30
Rated M Roadster
162
No spacers up front, but other coilovers might need them. I have rubbing from being so low and from the track, but under normal driving and at a normal height, you'll be fine (assuming you also have camber up front).
      11-08-2013, 01:37 PM   #31
Bandlu
Drives: Z4M coupe
Rated M i really like the wheels you have on your car. Maybe you can help me with a few questions. I have kw v3's installed on my car at close to the highest ride height possible. Would you know if i would get rubbing with the higher ride height? You mentioned that you don't have camber plates so i'm assuming I too wouldn't need these.
Would i be able to get the same concave look with a thinner rim?
Any help would be greatly appreciated.
thanks
      12-24-2013, 03:50 AM   #32
Paul46
Drives: E46 M3
Have you had your arches rolled mate. Great looking car by the way
Tags
apex arc-8, hankook rs3, m roadster, z4m
