10-27-2014, 03:47 PM | #67 |
Admiral
240
Rep 314
Also, be careful to not over torque the battery post clamp bolts, breaking the bolt. They are realy pricey to replace (about $20 each on ebay). Do not get the Audi ones if you need them, only the BMW clamp bolts will work.
10-27-2014, 07:18 PM | #68 |
More of this than that!
29
Rep 817
Exactly...snug is fine...otherwise it is broken, and expensive to fix. Several people noted that to me when I had to change out my battery. Glad I had that warning.
'06 Z4 3.0i Jet Black/ Biege/Black Leather / Premium Package / DICE Silverline DUO / Stubby Antenna / Matte Black Grill Ultimate Cup Holder x2 / Gaptech RCH+ / First Aid storagebox x2 / Acrylic Wind Deflector |
10-27-2014, 10:10 PM | #69 | |
Rep 273
The picture you referenced is for an M car, which has a different trunk mounted battery box arrangement. Last edited by WestCDA; 10-27-2014 at 10:31 PM.. |
10-27-2014, 10:51 PM | #70 | |
Rep 2,871
Drives: Anything
10-30-2014, 02:31 PM | #71 | |
707
Rep 7,850
12-27-2014, 11:25 PM | #72 |
your average JAMF
3147
Rep 4,096
As my car just passed its 8th birthday, it's starting to crank a bit slowly so I assume it's due for its 2nd battery replacement. I'll go with the O'Reilly AGM.
Note! Consumer Reports had a TON of problems with the H6 AGM battery from AutoZone - many failed prematurely, at a matter of WEEKS. They thought it was a fluke and tested more, with similar results. Must be a manufacturing issue or something. I have one in my ZHP that I put in about 2 years ago, no issues. I'll steer clear this time.
'21 M2 Comp
'19 Golf R |
12-30-2014, 03:21 PM | #73 |
your average JAMF
3147
Rep 4,096
So.. just replaced mine at lunchtime with the Napa 9848. Napa gives a 10% AAA discount, be sure to ask for it - even if you're not a member, because they probably won't ask to see your card.
Just realized that my old battery did not have a vent tube attached and none was in sight, and I slapped the new one in without it crossing my mind until now. It was a stock BMW AGM that had been replaced once under the 4/48 warranty. Should a vent tube be there? Should I be concerned leaving it there without one? It's been that way for 3+ years, but... sheesh.
'21 M2 Comp
'19 Golf R |
12-30-2014, 11:38 PM | #74 | |
Rep 2,871
Drives: Anything
01-03-2015, 07:36 AM | #75 |
Rep 18,767
Requesting some help...
Picked up a '08 Z4 3.0si Coupe from CarMax a few weeks ago. The replacement battery CarMax used is not nearly the correct physical size of the BMW OEM battery - it slides around. I am going to replace the battery with a BMW OEM (I have one from my E90 that is in good shape). My issue is the vent tubing is missing. I'm asking for someone to post a pic of the original OEM battery vent set up. The parts are a connection elbow, tubing and, a grommet. These are all the same parts on my E90, so I'm familiar with them. However on my Z4 the elbow is still with the car, but it is stuck in the vent hole in the floor pan. On my E90 the elbow attaches to the battery, not the car body. A pic of the original vent tubing set up will help me out with putting the battery installation back to original equipment standards. Thanks in advance. |
01-05-2015, 09:57 PM | #76 |
your average JAMF
3147
Rep 4,096
I'm going to venture back into mine to try to locate the tube too, so I'll take some pics. Not sure how soon I'll do it, probably won't have time till next week.
'21 M2 Comp
'19 Golf R |
01-21-2015, 01:00 PM | #77 | |
Rep 1,224
01-21-2015, 05:19 PM | #78 | |
Rep 18,767
Thanks for the post; it confirms what I thought was the OE set up. CarMax installed an H5-sized battery in my car, which doesn't fit with the sliding clamp mechanism, so soon I will get the H6-sized battery and swap it out. |
01-22-2015, 09:30 AM | #80 | ||
Rep 1,224
Following the various threads from those that have purchased from CarMax; batteries, oil, oil filters.... are always suspect.
05-25-2015, 07:52 PM | #81 |
Rep 175
Bought the O Rielys's battery today. It was the AGM 48PLT. Was an exact match of the oem. Did not have any fitment issues and seems to work just fine.
The store I went to was suggesting a 47 after looking at their database. I went with the info from this thread to make my choice. Thanks for the help! |
05-26-2015, 12:36 AM | #82 | |
707
Rep 7,850
10-10-2015, 12:42 PM | #83 |
Rep 3,004
Replacement Battery #2....
Vehicle manufacture date: Nov 2006
Vehicle sell date: Dec 2007 Pro-actively replaced battery: Jun 2011 Pro-actively replaced battery: Oct 2015 Both replacements: OEM Oct 2015 replacement: Cranked slow; able to drive vehicle immediately for replacement. Driving conditions: Only drive 5.5 miles to bus park and ride daily; 11 miles daily. Battery life cycle info: Typical info is 4-5 yrs. Comment: the S54 3.2L is 11.5 compression ratio; this adds additional battery cranking stress. Comment: If vehicle stranded, this vehicle requires a flatbed; expensive tow.
Racerbruce
11-02-2015, 04:33 PM | #84 |
Rep 1,107
Installed a NAPA 9848 over the weekend. Perfect fit replacement. I did find out that the Indy mechanic that replaced the battery when I bought my car 4 years ago (part of the PPI) did not hook up the vent tube and it was missing the final "L" bend to connect to the battery housing. Will be ordering part number 61211377835 when I make my next parts order from ECS or Turner.
10-14-2016, 05:15 PM | #85 |
Rep 666
My June 2007 build date Z4MC is still cranking on its original OE battery. During the winter months it is on a battery tender much of the time and stored in a garage.
Will replace as a prophylactic measure sometime soon. Looking at the NAPA 9848 as the replacement.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red SOLD: 2007 BMW Z4 M Coupe Imola Red |
10-15-2016, 09:46 AM | #86 | |
29
Rep 817
https://docs.google.com/spreadsheets...J7A/edit#gid=0
11-06-2016, 11:07 AM | #87 |
Rep 175
My battery died from sitting too long while in storage. My battery tender was faulty. Ended up replacing battery under warranty from o Reilly's after purchasing original battery in May of 2015.
Replaced with same Agm 48PLT. Good battery. Perfect fitment. Good servive. |
11-07-2016, 01:59 AM | #88 | |
707
Rep 7,850
Tags |
battery |
