02-24-2014, 11:08 PM | #1 |
Rep 175
To square or not to square? / tire size advice
Just bought a set of the Apex Arc-8s from the group buy. Specs are:
18x9.5 et 35, 18x10 et 25 Looking at picking up a set of Hankook rs3 or rs4 when they come out. Current suspension: ast4100 with Vorshlag camber plates. Was thinking of 2 choices for tires in running staggered 265/275 or run a 265 squared. Any major difference here in performance? I don't feel like rolling rear fenders to make a 275 fit. I know I'm likely to camber out the front and probably add a 5mm spacer. Car will see light track duty. Appreciate any input. |
02-25-2014, 05:18 PM | #4 |
Rep 279
I've been running my 17" wheels with 255/40r17 squared. AST 4150, H&R sways and more camber and the car is very neutral and with Direzza II's instead of the MPSS on my 18's, sticks! I will probably go 9.5 et 35 all around for my next 18" setup and run 265 squared.
06 Alpinweiss Z4M R Anthracite Apex EC-7 9F/9.5R, 245/275 Super Sport's, 17" Kosei K1 255/40r17 Direzza II, SS Lines, Pagid RS29, Ate SuperBlue, VT Comp. MM's, RE trans. mounts, AST 4150, Swift springs, Vorschlag camber plates, RE RSM, H&R swaybars, spherical rtabs, SuperFlex poly fcabs, StrongStrut Braces, Euro Headers, Stromung exhaust, ESS Tune, Eventuri intake |
02-25-2014, 10:14 PM | #6 |
Rep 279
Sweet! I'm betting the car handles really well with that wheel/tire combo. Yep, that'll be next.
06 Alpinweiss Z4M R Anthracite Apex EC-7 9F/9.5R, 245/275 Super Sport's, 17" Kosei K1 255/40r17 Direzza II, SS Lines, Pagid RS29, Ate SuperBlue, VT Comp. MM's, RE trans. mounts, AST 4150, Swift springs, Vorschlag camber plates, RE RSM, H&R swaybars, spherical rtabs, SuperFlex poly fcabs, StrongStrut Braces, Euro Headers, Stromung exhaust, ESS Tune, Eventuri intakeLast edited by mtrhed; 02-25-2014 at 10:15 PM.. Reason: cocktails |
02-26-2014, 12:20 AM | #8 |
Rep 516
-3 up front 5mm spacer. havn't tracked with this particular setup. but my other set is same fitment. Car handles more neutral imo with more tendency towards oversteer. Car rotates very well, great improvement
02-26-2014, 12:33 AM | #10 |
Rep 516
ive ran a 19x10 +25 with a 275 on stock suspension/alignment before. no rubbbing what so ever. no sure if lowered. with 265 +35 no modifications needed. I am actually running a 10mm spacer in rear to space it out also.
02-26-2014, 10:08 AM | #12 |
Rep 2,176
02-26-2014, 06:49 PM | #13 | |
Rep 1,739
Drives: 2008 Z4MC
02-27-2014, 12:31 AM | #14 |
Rep 175
02-27-2014, 07:15 PM | #15 |
Rep 1,739
Drives: 2008 Z4MC
02-27-2014, 11:53 PM | #16 |
Rep 175
So I guess it comes down to this:
Run 265 squared and be able to rotate/flip tires. No fender rolling / rubbing issues. Seems easy enough. Or run staggered 265/275 to gain more rear traction and possible tire advantage. Lose the ability to flip tires. May need rear fender rolling as suggested by Apex in another thread. I'm leaning towards the squared setup. Is a 265 too small for a 10" wide rim or am I fine here? |
02-28-2014, 12:13 AM | #17 |
Rep 516
im pretty sure you wont rub with a 275. if you're going to run staggered tires. i think a 255/275 is a better option. less worry of front rubbing.
02-28-2014, 12:30 AM | #18 | |
Rep 175
I'm just not sure if there is a meaningful difference in performance running a 275 on the rear vs 265. Wheels arrive Monday so I need to figure this out. |
03-01-2014, 11:38 AM | #21 |
Rep 175
03-03-2014, 10:47 AM | #22 |
Rep 515
Currently I'm running hre r43 wheels. 18x9.5 et 26 front and 18x10 et 22 rear. Currently running continental dw in 265/35/18 all around. I've run 275 nitto nt01's and 275 conti grand am slicks on them as well in the past. Suspension is now airlift performance series air suspension, running -2.8 camber, 8.0 caster, near zero toe in front. Rear is -1.8 and again very little toe. Handles really well on the street as well as track although for the track I prefer another degree of negative camber.
As far as how low... being air I can literally tuck the wheels if I'd like to. But I run it with about 1" of wheel gap. Here's the typical ride height. And a little lower. Last edited by angelr; 03-03-2014 at 11:11 AM.. |
