      01-15-2012, 06:58 PM   #1
phylo
Drives: 2003 Z4
DIY Strut replacement??
Hey guys,
I need to replace the struts on the front end of my 03 Z4 and was wondering how hard it is to do them myself.. I do have access to a lift so getting the car off the ground isnt a problem.
Im also wondering how the Bilstein struts compare to the stock sport suspension?
Phil
      01-16-2012, 01:22 PM   #2
SONAR
Albania
Drives: By echolocation
non MZ4 use E46 front struts, any E46 DIY should be close enough if not the same.
Here's one involving the E46 strut among other things
http://forum.e46fanatics.com/showthr...ght=diy+struts
      01-16-2012, 01:28 PM   #3
BruceJ
6 of Diamonds (ret)
BruceJ's Avatar
Drives: 2011 E93 335is
Not hard if you are mechanically inclined and have access to some good tools. There is a lot of similarity bet the E85 and E46 suspensions. If you dont get in a rush it should be pretty straightfwd. Only tricky part is spring replacement. Not to insult your intelligence but an alignment is needed once its all done.
Here are a couple DIY's
http://forums.bimmerforums.com/forum....php?t=1096399
http://forum.e46fanatics.com/showthr...aliper+rebuilt
Note on the 2nd DIY he takes his struts to a mechanic who has a hydrualic spring compresser. Not saying this is the only way but spring replacement is the big dog in the DIY. If you have not done them before, threaded rod spring compressors can be difficult to dangerous. I think getting access to a proffessional tool is the way to go.
Do a little searching on this site and the E46fanatic.com site for the Bilsteins. Both have suspension sections in the forums. If you havent done it already you need to decide what you are after:
1. BUDGET(600 to 3500)
2. Ride (comfy to chiropracters best friend)
3. Use(DD, track or both)
4. Height(slammed or stock HT to mildly lowered)
2007 Z4Si(gone)
Couple E30 Verts (DD)
2003 330i
2011 E93 335is - current fav
      01-16-2012, 03:01 PM   #4
Ovaltine
floor sweeper
Drives: 2007 Z4 Coupe
What's your current mileage -or- the mileage when you first thought your struts were going south? Just for reference...
      01-16-2012, 03:08 PM   #5
phylo
Drives: 2003 Z4
Current mileage is around 80K, I managed to go up over a curb and jacked things up a bit so it needs replacing.
And my intelligence is not insulted, I realize Ill need to get the alignment done afterwards..
      01-16-2012, 05:49 PM   #6
BIMMERGUY91
Drives: 2014 335I M Sport
The front is actually more like an e36 and the rear is like an e46. It is an easy install. If you have a roadster the rears can be a little tricky ive heard.
2014 335i M Sport
2010 328i M Sport
2007 Z4MC #1019/1815 (Sold)
1997 M3 (Sold)
1991 325i
      01-16-2012, 07:41 PM   #7
SONAR
Albania
Only for M variant, which uses E36 struts/knuckle and E46 LCAs up front. The non-M is almost straight up E46
      01-16-2012, 08:08 PM   #8
RedDotRacer
Drives: 07 Z4mc
A little off topic, but anyone know if we can swap the strut hats from left to right for more negative front camber on a stock setup?
      01-16-2012, 09:51 PM   #9
SONAR
Albania
u already shimmed? if not, most go for that first...another cheap (er) solution would be the RE fixed plates...but adjustable are not much more for the added benefit IMO.
      01-17-2012, 09:31 PM   #10
RedDotRacer
Drives: 07 Z4mc
No I haven't done anything. Just bought this car in Dec. I know tons about
e30's but nothing about these cars. Been doing a lot of reading. I'm trying to figure out how I can fit the Apex arc-8 18x9.5 et 35 up front on my car with the least amount of suspension change. (Sorry op, don't want to get off your topic).
      01-17-2012, 09:33 PM   #11
SONAR
Albania
Z4M's use the E36 front knuckle which can be shimmed. For people looking for cheap camber, this is typically the first route. I personally never did it, but you should be able to find more info searching. However, I don't think it will give you enough to fit a 9.5...plates are best option...what tire/size were you planning?
      06-10-2012, 04:21 PM   #12
JonnyM
525TDSlow
Drives: Silver E39 525 TDS
Will e46 coilovers fit a non M Z4?
      06-11-2012, 11:56 PM   #13
seank
enthusiast
seank's Avatar
48
5mm of shim spacers gave 1 degree more camber.
