      07-03-2017, 06:55 AM   #1
SwissArmy
Why so serious?
SwissArmy's Avatar
Any DIY tut on how to replace camber arms?
Hi there,
I am wondering if anyone can point me to a DIY guide on how to replace my BMW Z4 E85 camber arms? I bought a pair of adjustable camber arms and I would like to know what I'm getting myself into before I tackle it.
Thanks friends!
      07-03-2017, 02:41 PM   #2
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
They're pretty straight forward to install.
Tips:
- Put rear of car up on jack stands, not up on ramps.
- Remove wheels to reduce pressure on the bolts that hold the control arm in place.
- Use the OEM control arm as a guide and set the adjustable control arm to the same length as an initial starting point.
Top Down 365
      07-03-2017, 06:00 PM   #3
Steeler
Steeler's Avatar
2428
The upper(inner) connection is the worst part of the removal and install of the camber arms. It has a nut affair with a stem on it that you need to hold up inside the recess on the subframe.
As always work with caution. Always use jack stands
