07-03-2017, 06:55 AM | #1 |
Why so serious?
141
Rep 743
Any DIY tut on how to replace camber arms?
Hi there,
I am wondering if anyone can point me to a DIY guide on how to replace my BMW Z4 E85 camber arms? I bought a pair of adjustable camber arms and I would like to know what I'm getting myself into before I tackle it. Thanks friends! |
07-03-2017, 02:41 PM | #2 |
Rep 758
They're pretty straight forward to install.
Tips: - Put rear of car up on jack stands, not up on ramps. - Remove wheels to reduce pressure on the bolts that hold the control arm in place. - Use the OEM control arm as a guide and set the adjustable control arm to the same length as an initial starting point.
Top Down 365
07-03-2017, 06:00 PM | #3 |
Rep 2,702
The upper(inner) connection is the worst part of the removal and install of the camber arms. It has a nut affair with a stem on it that you need to hold up inside the recess on the subframe.
As always work with caution. Always use jack stands
