      12-23-2014, 10:10 AM   #1
jjr
jjr's Avatar
Drives: 2006 BMW Z4 3.0si
Cool 06 Z6Si Radio Stays on w/ Ignition Off??
Hi,
Is there a way to set the radio to turn off with the key?
TIA,
HAPPY HOLIDAYS!
      01-30-2015, 05:05 AM   #2
darknetone
darknetone's Avatar
Drives: 2011 Z4 and 2003 Z4
I assume this is not a factory radio. Yes, wire the radio to a switched fuse location that switched, the two original radio fuse locations provide a switched and a non switched location. This is probably the best easiest way.
Keep in mind some radios. Will usuall have on switched power line an one that is not, the one that is not keeps the radios clock, memory and the like alive.
      01-30-2015, 07:46 AM   #3
jjr
jjr's Avatar
Factory radio, I read the manual and the radio will turn off 20 minutes after the ignition is turned off or the radio is turned on w/ the ignition off. I tried it and it works ;-)
Thanks though
Tags
radio off
