11-24-2013, 07:34 PM | #1 |
Rep 104
How many rattles does yours have?
Roads here in Idaho seem to get worse as it gets colder, I think the roads start to heave just like the side walks. So with the top up to keep warm of course I can notice every little noise. I must say these are tight little cars. My Z4 only has two rattles that annoy me and only on rough roads. One I have found and am going to take care of this spring, the other on the passenger side that I have not found yet. How about yours?
11-24-2013, 07:49 PM | #2 |
#dubspec
6337
Rep 5,201
No rattles at all. Mine is on h&r coilovers with rpi exhaust. My drivers side seat is squeaking a bit, so I will remove it this winter and tighten it up
11-24-2013, 08:52 PM | #3 |
1621
Rep 4,294
No rattles here, just an annoying sub sound high pitch squeal that increases pitch with speed at the back somewhere. Though only present between 90-110km/h. I thought it was a wheel bearing, but it persists., maybe it's the tire.. But zero rattles.
Powered by |
11-24-2013, 09:54 PM | #5 |
Rep 104
And I thought two rattles was nothing! Looks like I have some fixing to do. The one rattle on the passenger side I have not figured out I believe is the right pillar support where it meets at the dash, the plastic part.
11-24-2013, 10:51 PM | #7 |
Rep 12,565
driver side door card/handle
11-25-2013, 12:43 AM | #8 |
636
Rep 3,124
Passenger's side cup holder.
Navi screen. Stops once the Sun shines on it for a while. Drives my crazy first thing in the morning. Both visors. More of a leather on leather squeak, but even more annoying than a rattle. Something in the area of the ashtray hits a resonance at 2500 rpm under acceleration and "beeps" for about 1/2 second as I pass through the resonant range.
11-25-2013, 05:43 AM | #9 |
Track Addict
110
Rep 813
Drives: 2010 BMW M3 E92 | 2008 Z4M E86
Mine makes all sorts of noise… I believe 6-7 places at least… Many panels feel like they'll make noise… I just turn on the music to wash them out.
BMW ///M3 Coupe
Completed November 16, 2009 Received December 29,2009 |
11-25-2013, 08:13 AM | #11 |
Rep 1,134
Drives: '07 M Roadster
Rattles? Can't hear them over the RPI's screaming and the wind with the top down.
11-25-2013, 08:31 AM | #12 |
Mechanical Engineer
96
Rep 1,025
1. back/bottom of drivers seat
2. drivers vent 3. passenger vent 4. drivers a pilar 5. windshield surround 6. nav (only once in a great while). 7. dome light think i just found a permanent fix for vent rattles, will post it up when I'm sure |
11-25-2013, 08:44 AM | #13 | |
Rep 165
11-25-2013, 09:18 AM | #14 |
Rep 1,107
A little while ago I had an irritating little creaking from the bar that retains the shoulder belt to the side of the seat. Spraying in some vinyl cleaner seemed to resolve it but it caused me to do some research on special purpose lubricants that the automotive industry might use for all the various contact points in a car interior that would start making noise over time.
I found this: http://www.dowcorning.com/content/ne...news_EM30L.asp And purchased this: http://www.ebay.com/itm/Grease-Lubri...item3f092ff114 I haven't used it yet, but the cold winter seems to bring out the noise in BMW interiors. |
11-25-2013, 10:02 AM | #15 |
Rep 924
Shifter knob at 5000+ RPM. I've tried wrapping the shaft with tape and poster putty, but doesn't help much. It makes me not want to hit that RPM -- I'm conflicted whether that's good or bad.
11-25-2013, 10:25 AM | #16 |
Zed Head
314
Rep 233
Drives: 2020 BMW Z4 M40i
My Z4 doesn't have any rattles other than the passenger belt buckle tapping against the side if I don't have it positioned just right when there is no passenger, however it had what sounded like styrofoam rubbing against something and squeeking in the roll hoops and the cupholders. These noises drove me so crazy I was considering selling the car. Then I had a thought that maybe a little lubricant would help so I sprayed all seams and joints with WD-40, the car smelled awful for a couple of days but after a year I still have no squeeks.
11-25-2013, 02:48 PM | #17 |
Mechanical Engineer
96
Rep 1,025
I used to have really bad rattles from the roll hoops. I wrapped both of them very tightly with cloth hockey tape (think of how you'd wrap the bottom of the hockey stick). Completely fixed the problem, and you can't see it because I have the wind deflector installed over the top.
11-27-2013, 04:39 PM | #18 |
Rep 251
The Navi screen rattles pretty bad when at idle. I had others coming from drivers cup holder and vents... I also get a lower back massage while waiting at red lights... and that's because I have aggresive poly... motor mounts.
Once I go over 1.2k rpms.... nothing rattles and I love the way the car feels. |
11-27-2013, 06:14 PM | #19 |
Rep 662
Current: Z4MCoupe, Interlagos Blue, Carbon Extended Leather, Sat Nav, Heated Seats, Supersprint Exhaust, BBS CH19's, Stubby Aerial. AND E82 1M, Alpine White
Sold: 3 x 130i (White, Red & Black), Mk4 VW Golf R32, '03 Reno Clio Sport |
12-02-2013, 12:52 AM | #21 | |
Rep 820
Drives: 2007 Z4MR silver grey
John |
12-02-2013, 09:00 AM | #22 |
Rep 14
Both of my door lock pins rattle depending on the road I am on. Trying to figure out some kind of solution. Maybe some rubberized ones are on the market somewhere?
