      09-26-2011, 07:03 AM   #45
Drives: M2 Comp
With #2
I don't really like the idea of holding the bushing in place with a set screw.
JMO, but it seems like something that could be problematic over time.
      09-26-2011, 09:14 AM   #46
BookerM3
BookerM3's Avatar
Drives: Z4 M Coupe
With #2
I've used Factory rubber, Delrin and Spherical offeset control bushings in my
E30 none of them used a set screw, they were all press fitted, only a small
dimple on the bracket located the bushing.
Something like this would work (with Poly instead of Delrin inserts)
http://www.ground-control-store.com/.../II=894/CA=243
I purchased an E46 M3 Setup that I was planning on modifying over the
winter. If Rogue doesn't come through, I will fab up something.
I'm really keen on this part as I found the M coupe wanders badly under
heavy braking (track conditions). I'm pretty sure this mod will solve this.
      09-26-2011, 09:22 AM   #47
Drives: M2 Comp
^interesting
I'm keen on this as well.
If R.Eng doesn't go ahead & you end up fabing something, be sure to post it up.
      09-28-2011, 02:00 AM   #48
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
They are a great looking set of bars.
I'm not a fan of the oversized slotted holes on the tower rings.
The holes measure +10.6mm for a stud that's less than 8mm
The slot (13.5mm) just makes it worse to get a decent clamping force.
With the countersunk holes it makes it difficult to use a larger washer.
I have mine off right now.
The washers are all dished & you can see that the hole locations are starting to dish as well.
To me this means that things must be moving.
If I keep the StrgStrut bars I'll figure out a way to mod them.
If there is a better set of bars (functional) out there, I'll may just sell the StrgStrut bars.
See my post on the DIY section for a possible solution if you wanted to try it as well => http://www.zpost.com/forums/showpost...3&postcount=71
      09-28-2011, 06:42 AM   #49
Drives: M2 Comp
thanks.
I did the same thing a few weeks ago.
I also used case hardened washers.
      09-29-2011, 07:40 PM   #50
F360C
Drives: E86 S54
Alright so I was at Rogue again today with my brother and this project is coming along. The needle bearing is the leading solution but depending on the NVH the replacement extra hard stock style bushing may prevail. My borthers car will be at Rogue early next week to have some things test fitted. I will fill you guys in on the results. Some parts possibly may be track tested next weekend at New Jersey Motorsports Park on my brothers car.
07 Z4 M Coupe AW/IR
      09-29-2011, 08:26 PM   #51
Drives: M2 Comp
Thanks for the update.
Sounds great!!!
      09-30-2011, 03:37 PM   #52
Z4-PM
France
Drives: Z4MC
Very promising...
Feed-back is welcome on pros/cons.
Z4MC / ZR CDV / G-Power exhaust / RE X-Pipe / GruppeM / NGK Irridium plugs / Sport System ECU / RE RTABs & RSMs / Bilstein B12 / VMR VB3 Michelin PSS / M Strut / AP Racing 6x4
      10-28-2011, 05:03 AM   #53
MFGJR
Drives: 2007 Z4 M Coupe
Any update on the FCABs?
      10-28-2011, 09:07 AM   #54
Beedub
Im on for a set of FCAB..........
i will be going all out on the suspension side of things on my car so this can be added @ the same time.
      10-28-2011, 08:25 PM   #55
F360C
Drives: E86 S54
Alright so work has been progressing and he has what has been done so far.
Before Ben went and designed a new set of off set bushings he wanted to see what effect an E46 M3 centered bushing would have on the car. So we used my brothers car as the guinea pig. What we did was to go to Rogues trusted alignment shop, Northeast Motorsport, and have the car aligned and corner balanced with the stock bushings to my brother preferred track specs. Then after that we took out the stock bushings and installed the Rogue E46 M3 bushings. After those were in the car we aligned and corner balanced the car again. The reason this was done was Ben was thinking that with the centered bushing we would not be able to get the correct caster settings. Turns out we were able to align the car perfectly. Next up we put the bushings to the test and took both of our cars to a two day track day at NJMP and the results were promising but not perfect. Overall the bushings really helped the car. Turn in was improved and handling throughout the corner was more consistent especially in the high speed stuff. Combine these bushings with his spring weight (700lbs front/850lbs rear) and the car was razor sharp! I was jealous he has them and I didn’t. Now for the down sides...
By using a centered bushing it moves the wheel towards the rear of the wheel well. This can be okay if you are using a skinny tire like we use but if you were lowered and were using a thicker OE style tire it would cause and issue with rubbing the center rear of the fender liner. In addition these could only be used if you had after market camber plates. This is okay for guys like us who have all the suspension mods but for guys that don't have camber plates these bushings could not be used. So back to the drawing board! An offset bushing will have to be used. So his current thought is to machine a new housing similar to the OEM housing but to machine it so we can use the RE E46 M3 bushings but instead of the bushing being offset he will machine it so the whole housing is off set.
After all the work we have done so far I can understand why people have said they will make the bushing but then they end up not making them. There is just no easy solution. Fear not though... Ben and the guys at Rogue are going to come up with a solution!
07 Z4 M Coupe AW/IR
      10-28-2011, 08:52 PM   #56
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Great news, and thank you for the work on this (and the brace). Great R&D and testing procedures.
Like I said earlier, I'm in!
      10-28-2011, 08:55 PM   #57
Shipkiller
Shipkiller's Avatar
Drives: Me
I will be a customer for the new bushings....
      10-30-2011, 12:24 PM   #58
wyatth
Drives: E90 ZCP
Great news about the offset housing and the E46M style bushing! Cheers
      10-31-2011, 08:51 AM   #59
Drives: M2 Comp
+1 Great way to do this.
      11-28-2011, 05:16 PM   #60
Z///Ms
Z///Ms's Avatar
Drives: Z3M Rstr, Z3M Coupe, Z4M Coupe
When they have the solution, I'm a customer. And hopefully it's before next spring and the start of track season!
      11-29-2011, 03:19 AM   #61
johanness
Drives: 2008 Z4MC
Any update on the RE strut brace?
      12-05-2011, 05:40 PM   #62
BIMMERGUY91
Drives: 2014 335I M Sport
Interested in fcabs and the strut brace! Keep the good work and updates coming
2014 335i M Sport
2010 328i M Sport
2007 Z4MC #1019/1815 (Sold)
1997 M3 (Sold)
1991 325i
      12-07-2011, 08:03 PM   #63
BIMMERGUY91
Not trying to take away from RE i love their stuff but if anybody is wanting FCAB's right now Powerflex has some. http://www.europeanautosource.com/pr...ultiple-models
2014 335i M Sport
2010 328i M Sport
1997 M3 (Sold)
1991 325i
      12-07-2011, 08:45 PM   #64
BookerM3
BookerM3's Avatar
Drives: Z4 M Coupe
The problem with these is that they are not offset like the ones on an M.
There the right ones for a standard Z4.
      12-07-2011, 09:00 PM   #65
BIMMERGUY91
Ugh I wish people would get their shit together. Alot of stuff I see is listed as for the z4 and z4m and its really not for the M.
2014 335i M Sport
2010 328i M Sport
1997 M3 (Sold)
1991 325i
      12-07-2011, 09:51 PM   #66
F360C
Drives: E86 S54
Small update....
Had a test fit of the plates for the strut brace alittle over a week ago. Hopefully soon we will have the bar back from Mason for any final adjustments. I am hoping I can have the final version on my car before Christmas!
07 Z4 M Coupe AW/IR
