      04-07-2014, 03:58 AM   #23
Beedub
Originally Posted by StickMon View Post
I would guess you'd be fine to 20k.
You'll hear the heads rattling around pretty loudly before 3 or more are broke, so just keep an ear out for a lot of ticking.
hell while I'm in their i may as well change the vanos hub to the dr vanos upgraded unit..... seems silly to have all the labour of changing out these bolts to not do some upgrades while I'm in their...
byron
      04-07-2014, 02:47 PM   #24
StickMon
StickMon's Avatar
Drives: 2006 MR
And don't forget the chain guide.
I was unprepared last time and didn't change mine, or even inspect it.
      04-08-2014, 01:34 AM   #25
Beedub
definitely....
      04-08-2014, 02:00 AM   #26
bignosejim
bignosejim's Avatar
Drives: 2007 IB M Coupe
I think getting a pump disc with smaller holes is the key to preventing broken tabs. If your hub is intact, then reducing the clearance between the tabs and pump disc will keep them from hitting each other with enough force to cause the tabs to break.
/// Vibra-Technics motor mounts /// Autosolutions SSK /// RE Tranny mounts /// Aero Turbine Exhaust /// Beisan Vanos upgrades /// SDW rtabs /// Fortune Auto 500
