04-02-2014, 05:48 PM | #1 |
Rep 420
S54 Cam Bolt issue, dealer says 15 hours labor!
Hi guys, so I had a rattle in the valvetrain and decided to take it to my usual dealer. They did an inspection 2 which was due, and then they diagnosed the rattling sound that I told them about as loose cam sprocket bolts. A little research yields that this is a common issue for S54s. However, according to the dealer, in order to fix this issue, they need to pull the bumper, rad support, headlights etc out so they can extract the vanos unit and look at it and fix the bolts that have broken / sheered / loosened / whatever the hell is going on in there. They quoted me 15 hours to do the job. Has anyone else had to resolve this issue? Does this sound right to anyone else?
04-02-2014, 05:57 PM | #2 |
636
Rep 3,124
I had my bolts replaced by a "reputable" indie that told me the same thing, and charged me up the gazoo.
It's bull-hockey. Here's me pulling my Vanos and replacing the exhaust hub. All I removed to get the Vanos out was the hood release cable, and I'm not sure that was even necessary. While you're worrying about the bolts, you might as well worry about the exhaust hub tabs and the plastic upper chain guide.
04-02-2014, 10:59 PM | #3 |
Rep 2,860
OP...Since you're in SoCal, join M3Forum and PM "Kaiv". He has been "wrenching" on my Coupe and X5 for the past couple of years...couldn't recommend him enough. Best of all, if you pay for his gas, he'll do house call!
Here's a running review of his work => http://www.m3forum.net/m3forum/showthread.php?t=352554 |
04-03-2014, 05:52 PM | #4 |
Rep 1,107
So if I'm going to have my indie check on my Vanos bolts (when he does my inspection II next year), would it really just make best sense to hand him a Dr. Vanos hub and have him replace it outright? These tabs breaking off sound like they are just inevitable.
04-03-2014, 07:17 PM | #5 |
636
Rep 3,124
If you're going to pull the hub anyways, it's probably worth it, and replace the upper chain guide.
I thought from late 2006 on they came from the factory with the torx bolts. I don't think you're susceptible to the sheared bolt phenom.
04-03-2014, 10:28 PM | #6 |
Wagon life
39
Rep 991
I had it. I had it bad. Don't believe that guys! Not calling you a liar bud but I have evidence to the contrary. The problem still exists.
04-03-2014, 11:07 PM | #7 | |
Rep 175
04-03-2014, 11:12 PM | #8 |
Rep 2,782
Late 2006 is when the changeover occurred. It's based on engine build date. I've asked the questions a few times - how do you determine engine build date, and what engines have new bolts? I don't want to pay ridiculous labor costs only to find out I have the correct bolts, and I don't like running around feeling like my engine may grenade at any time.
A car built in July 2006 had the old bolts. One built in December 2006 had the new ones. Mine was built in September 2006, right around the changeover. Again, it's based on engine build date and not vehicle build date, so I have no idea if you can even use the car's date to determine bolt type.
04-03-2014, 11:14 PM | #9 |
Rep 892
Same here; 4 out of 6 intake bolts in pieces with 30k miles on the car.
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i |
04-03-2014, 11:18 PM | #10 |
Wagon life
39
Rep 991
04-04-2014, 04:16 AM | #11 |
Rep 279
I plan on "Kaiv" doing a full rebuild on my "VANOS" here soon(95K). Parts ( Beasian Hub and seals)+ about $800 labor. Was going to attempt myself but too much other stuff on my plate. Would never consider a dealer to do the work. If in SoCal, get ahold of "Kaiv".
06 Alpinweiss Z4M R Anthracite Apex EC-7 9F/9.5R, 245/275 Super Sport's, 17" Kosei K1 255/40r17 Direzza II, SS Lines, Pagid RS29, Ate SuperBlue, VT Comp. MM's, RE trans. mounts, AST 4150, Swift springs, Vorschlag camber plates, RE RSM, H&R swaybars, spherical rtabs, SuperFlex poly fcabs, StrongStrut Braces, Euro Headers, Stromung exhaust, ESS Tune, Eventuri intake |
04-04-2014, 09:58 AM | #12 | |
Rep 2,860
Are you doing the "rattle kit" as well? How's your bearings? Have you done those yet? Last edited by XMetal; 04-04-2014 at 11:15 AM.. |
04-04-2014, 10:17 AM | #13 |
Mechanical Engineer
96
Rep 1,025
Will he come up to San Francisco for a big job like that?
Such a luxury you guys have, being able to get service from Kaiv. I do my own valve adjustments, but I think the Vanos stuff is a little bit too far for me. I could probably figure it out, but the financial risk of trashing an engine is more than I can handle. |
04-04-2014, 11:12 AM | #14 |
Rep 2,860
Just your luck...someone is actually organizing a trip for him to wrench in northern cal => http://m3forum.net/m3forum/showthread.php?t=472063
04-04-2014, 11:06 PM | #15 |
636
Rep 3,124
So are you saying you had hex heads in an engine with a later build date, or you had torx heads shear off?
04-05-2014, 12:15 AM | #16 |
Rep 279
I do plan on having him do the rattle kit as well as everything else. If my Blackstone reports are a true gauge of engine health I think my bearings are doing well. Engine always gets fully warmed before getting on it and almost all of my miles are open road with not a whole lot of time spent at high rpm, mid-range mostly. Almost no city driving and no lugging.
04-05-2014, 08:23 AM | #17 |
Wagon life
39
Rep 991
04-05-2014, 12:05 PM | #18 |
Rep 2,860
^Looks like hex on the only bolt head that I could see.
04-06-2014, 10:32 AM | #19 |
Rep 5,327
my car is a feb 06 build.... currently at 11k miles... i think ill take it this summer to get these bolts changed.... mine must have the old type and get used pretty hard tbh... I'm worried about it.
04-06-2014, 12:53 PM | #20 | |
636
Rep 3,124
Yep, looks like hex. AFAIK, nobody has reported broken torx, but I haven't done much searching.
Exhaust hub went somewhere around 80k.
04-06-2014, 01:52 PM | #21 |
Rep 5,327
hmmm, do you think id have much issue waiting till 20k?? never heard of these failing sub 20k tbh/....
04-07-2014, 12:35 AM | #22 |
636
Rep 3,124
I would guess you'd be fine to 20k.
You'll hear the heads rattling around pretty loudly before 3 or more are broke, so just keep an ear out for a lot of ticking.
