09-01-2013, 05:07 PM | #1013 |
instagram 997turbotom
286
Rep 7,377
I tried to remove my pulley with a pulley puller but there wasn't enough clearance to make it grab. Then I tried various pry bars, but they apply pressure to the grooves, and I didn't want to break my old pulley. Guess I'll leave this part to the professionals
09-01-2013, 05:58 PM | #1014 |
Rep 892
You're seriously going to pay someone to do this? Use a torch to heat it up and it will slide off.
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i |
09-02-2013, 01:33 AM | #1015 |
Rep 5,329
mine got damaged when the shop used a puller to remove to pulley, i hope you havent damaged the main seal..... good luck..... it really is a delicate item.
09-02-2013, 11:23 AM | #1016 |
286
Rep 7,377
the square key is kind of laying at an angle, giving it a lot more friction. I'll try a torch
09-03-2013, 06:29 PM | #1017 |
286
Rep 7,377
I tried to work it when the engine was hot, and still no go with arm pulling. I think the majority of the friction is coming from the key being stuck at an angle. Any suggestions?
09-03-2013, 07:22 PM | #1019 |
286
Rep 7,377
09-03-2013, 08:13 PM | #1020 |
Rep 2,706
Possibly drill the key stock out or try an easy out.
Run the easy out in until it binds and while holding the snout of the pulley try rotating what's left of the key stock back until it's square to the key way. It looks like that key stock is too small for the key way It should not have rotated like that. GL Dave
09-03-2013, 09:26 PM | #1021 | |
286
Rep 7,377
09-03-2013, 09:27 PM | #1022 | |
enthusiast
48
Rep 1,695
09-04-2013, 12:16 AM | #1023 | |
636
Rep 3,124
You'll have to carefully drill down the center of the key, starting small, and then with successively larger bits until the walls are so thin it collapses/shears. And the key is too small, too soft, or both.
09-04-2013, 08:36 AM | #1024 |
286
Rep 7,377
Awaiting suggestions from Vortech..
Drilling seems like a reasonable idea. Too bad I have to take the supercharger out
09-04-2013, 12:01 PM | #1025 |
286
Rep 7,377
advice from Vortech
"Tom, one of two ways either one will work.. you can heat it up with a small propane torch, do this by going in a circular motion around the outside edge of the blower pulley.. the pulley will start to sweat when that dries up the pulley should slide off. The second way is to just use a pulley puller to get it off. What is happening there usually occurs if one the pulley bolt was loose or the key is too small for the hole."
09-10-2013, 08:49 PM | #1026 |
286
Rep 7,377
Did some regular maintenance: replaced the windshield weather strip, put instructions in the DIY subforum http://www.zpost.com/forums/showthread.php?t=887578
Replaced the 1 year old hydraulic tensioner. Very proud that I did it myself actually. There is noticeably less slack now. Will test for boost differences. I'll go post a DIY http://www.zpost.com/forums/showthre...8#post14645768 I'm attaching a pic of the bracket I made to hold the lower intercooler pipe, as per someone's request
09-11-2013, 12:40 AM | #1027 |
Rep 2,782
You must get regular manicures.
09-11-2013, 03:28 AM | #1028 |
Rep 5,329
well done tom!!! think you have the most miles on a s/c kit.... keep going broski!!
09-11-2013, 03:37 PM | #1029 |
286
Rep 7,377
lol, no, not even once. Actually have dirt under my thumb nail right now
09-11-2013, 03:37 PM | #1030 |
286
Rep 7,377
Thanks! its probably the second most complicated repair I've done by myself, very proud of me
10-19-2013, 11:07 AM | #1032 |
286
Rep 7,377
wow. My oil filter housing needs to be replaced again. the long bolt that hold the hydraulic belt tensioner, broke off a chunk where it screws in... wow..
this is on a new hydraulic belt tensioner and on a stock pulley
10-19-2013, 01:06 PM | #1033 | |
Rep 5,329
WTF.... surely this cant be co-incidence?? could it be possible that their is excessive vibrations or anything else going on???? one i could call it bad luck, 2 units failing?? hmmmmm investigation needed!!
10-19-2013, 01:10 PM | #1034 |
286
Rep 7,377
I dunno man. the replacement unit I bought was a used one, I'll be buying a new one this time. The piece that keeps breaking off is so thin, I'm asking VAC motorsports if they ever re-inforced it.
