03-19-2012, 01:33 PM | #1 |
Rep 4,531
UUC E46 M3 SwayBarbarian Fitment
I just got off the phone with Rob at UUC and had an interesting discussion with him.
It appears that the rear bars in their kit, shown below, are guaranteed to fit the Z4Ms because their part number is an exact cross reference to the E46 M3s. http://www.nexternal.com/shared/Stor...t=products.asp However, the same doesn't apply to the front bars. He offered to sell me the kit, and take a refund on the bar if it doesn't fit, as he is interested as well if it will. Anyone have any experience with this? Is this a decent risk to take? Would running a rear-bar only have negative effects if the front bar doesn't fit and I have to find somewhere else to source it from? |
03-19-2012, 01:49 PM | #2 |
Rep 1,031
If you just do the rear depending on how much stiffer it goes it just affects under/over steer. I think a thicker bar in the back induces more understeer. Would wait for a better response from the boys that track and have way more knowledge than I do.
03-19-2012, 01:49 PM | #3 |
Rep 855
Well it would definitely change your understeer/oversteer characteristics just running the rear bar. The Z4 is already lacking in front end grip and running a stiffer rear bar is going to make that worse. You can get a front bar from Ground Control. I have also read that the m3 bar can be modified to fit the front. I would take the risk for the sake of the community!
2014 335i M Sport
2010 328i M Sport 2007 Z4MC #1019/1815 (Sold) 1997 M3 (Sold) 1991 325i |
03-19-2012, 03:03 PM | #4 | |
Rep 666
And you want aftermarket swaybars because???
UUC sells H&R bars that fit the Z4M but hardly worth the trouble; H&R bars are 28mm front and 21mm rear while the OE bars are 27mm front and 22.5mm rear. The Ground Control Z4M sway bar set is more aggressive if that's what you're looking for. http://www.ground-control-store.com/.../II=819/CA=231 Quote:
Jim Millet
03-19-2012, 03:18 PM | #5 | |
Rep 4,531
I realize H&R has solutions, but like you said, it's only a 16% increase. I know ground control is out there...but they never update their site and always says out of stock. I guess it calls for an email |
03-19-2012, 03:26 PM | #6 |
707
Give Jay at Ground Control a call. Their website might not be the most up to date, but he's a great guy, and will be happy to answer questions. Worth a shot at least!
03-19-2012, 04:29 PM | #7 |
Rep 170
I'm running the Turner E46 M3 bars on my car F+R no fitment issue.
However, I did change the rear end links to Hotchkis adjustables. I'd bet that the UUC's would likely fit aswell. |
03-19-2012, 04:58 PM | #8 |
Rep 4,531
I've been contacting TC Kline and they are looking into alternatives for something to fit with my car.
With being local, I want to go with these people. This is what they have to offer for E46 M3s H&R 30mm http://www.tcklineracing.com/webdocs.../Details96.cfm RE 31mm http://www.tcklineracing.com/webdocs...Details497.cfm Anyone confirm these? |
03-20-2012, 09:46 AM | #9 |
Rep 855
So you have e46 m3 bars on yours with no problem? I know the rear is the same
But I thought the front was different
2014 335i M Sport
03-20-2012, 10:00 AM | #10 |
Rep 170
03-20-2012, 10:11 AM | #11 |
Rep 855
Well that changes things. I'll just get e46 m3 aftermarket sway bars
2014 335i M Sport
03-20-2012, 10:29 AM | #12 |
Rep 4,531
Just to confirm, these?
http://www.turnermotorsport.com/p-26...y-bar-kit.aspx If so, that's awesome! Any specific reason why you changed the rear end-links? |
03-20-2012, 11:08 AM | #13 | |
Rep 170
I changed the rear and one of the front endlinks to allow for corner balance adjustment. Also, figured since nobody would confirm fitment, the extra adjustment range on the rear would ensure proper clearance to the half shafts. I never tried the stock rear endlinks so I can't confirm if these will work. |
03-20-2012, 12:41 PM | #14 |
Rep 1,663
If you get beefier sway bars, keep on eye on your frame (or preemptively re-enforce) as per this thread.
03-20-2012, 01:58 PM | #16 | ||
Rep 4,531
Hrm. |
03-20-2012, 10:15 PM | #17 |
Rep 855
Because the larger sway bars has less give so it puts more stress on them mounting point
2014 335i M Sport
03-21-2012, 06:22 PM | #18 | |
enthusiast
48
Rep 1,695
Just to clarify that just a larger sway bar in the rear will increase over steer, not
03-21-2012, 09:51 PM | #19 |
Rep 4,531
I ordered a H&R 30mm Front Sway from TCKline Racing after talking to Erik.
He insisted that a rear bar will yield no gain, but he would love to sell one to me if I still wanted it....of course I passed. Erik has had experience with racing Z4Ms, so I respect his opinion. He told me to run the rear bar, and if I can't rotate the car, then remove the rear bar completely. |
03-21-2012, 10:21 PM | #20 |
Rep 855
cant wait to hear what you think about it! I may be ordering one if you think it makes a nice improvement
2014 335i M Sport
03-21-2012, 11:06 PM | #21 |
Rep 4,531
03-22-2012, 04:52 AM | #22 |
Rep 912
I still have the rear 21.5mm Bar on my ///M Roadster, is it better to get the 22.5 mm bar for a firmer rear ?
Any idea why BMW ///M desgined the rear roll bar of the roadster softer than the coupe? |
