      10-03-2011, 09:56 PM   #1
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
2008 BMW Z4 3.0si  [9.00]
Suspension sqeaks?
Recently, I've noticed my rear driver side suspension squeaking as I get into the car. Anything to worry about? I'm not a heavy guy. I only weight 170 pounds. It concerns me only because I've got a 2002 Honda Civic and that thing doesn't squeak at all. Is this something I should have the dealer look at? My Z4 3.0si has less than 17,000 miles. Should the sport suspension start going bad at this point or does it just need a lube job?
      10-04-2011, 07:57 AM   #2
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6332
Do you hear anything while driving? It may just be your handbrake making a squeak because it's not tight
      10-04-2011, 10:47 PM   #3
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
I usually drive with loud music. Let me test it tomorrow if the weather is good.
      10-04-2011, 11:23 PM   #4
The HACK
The HACK's Avatar
1821
Don't pull up on the hand brake.
      10-06-2011, 05:15 PM   #5
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
Thanks. You guys were right. It was the handbrake.
      09-08-2013, 12:07 PM   #6
magnet
Norway
Drives: 2006 BMW Z4 Coupe 3.0si
I have the same "feature."
How exactly do I grease the handbrake wire to fix this?
Can I do this from the cabin with an aerosol can?
I removed the wheel to see if I could find any obvious grease-points, but I didn't.
I couldn't reproduce the sound with the wheel off either. And I didn't want to guess-grease anything that close to the brakes.
Thanks.
      09-09-2013, 08:52 PM   #7
Gallardo Rosso
Drives: 2007 Z4M Coupe
I believe the squeak is the result of the pad moving on the rotor. As you add and remove weight from the car the ride height changes and the wheel moves thru an arc. It probably is a fair amount of torque being generated by the small ride height change.
Nothing to worry about... either ignore it, set the brake harder or find quieter rear brake pads
      04-16-2014, 09:36 AM   #8
sl03
Drives: 2003 BMW Z4 2.5i
I've been noticing that my left rear wheel squeaks every time I enter the car and when I'm going over speed bumps as well
      04-16-2014, 07:09 PM   #9
Clearancediver
Drives: 2004 Z4
Think it's the RTAB ... I have the same squeak.
Sent from my smart phone...
