      07-10-2012, 12:51 PM   #1
StigJ
StigJ's Avatar
Norway
332
Drives: '06 Z4 Coupe & '14 F30
Ignition/start failure
I've had some problems now and then with my Z4 Coupe that it would not start. Did run a diagnostic last year but nothing came up. Just some communication errors that we did not find any answers to. I think also my Intravee is making some mess.
So I started investigating a little
In the video below you can see that when I move the key from step 1 (acc) to step 2 (ign) sometimes only the airbag light lights up in the ign position. When try to start the starter kicks in, but that is it. So there is no difference between acc and ign.
If I take the key out and try it again it usually works fine.
Here you can see what happens:
So I asked my mechanic what it could be. Try to change the ignition switch he said. Its just the last part that the wires goes in to. Its not the complete lock.
Ok. so I first checked how much a new one would set me back. Almost 120$. Yeah right! So I bought two used ones for 15$ (for both). Bought two if one of them would fail.
Then time to do the change.
here you see the two switches.
Its no. 3:
http://realoem.com/bmw/showparts.do?...84&hg=32&fg=30
Off with the bottom part of the steering column. Its only one screw just beside the lever for adjusting the steering wheel. Then wiggle it a little to get the two pieces to part.
Here you can see the ignition switch where the wires is connected.
Just pry the little lock to disconnect it.
The switch is held in place by two small flathead screws that is located under the red screw locking paint.
Just loosen them a litle and pull out the switch. Put in the new one and fasten the screws and connect the plug. Now you can do a test if its working as it should.
It looks like I found the problem and got rid of it
I put some screwlock glue back in the holes and reassembelede the steering column. Now its to hope that the problem stays away.
As the nosy person that I am I had to open the old switch to see what was wrong. Looks like its wear and tear on the plastic.
The second step (ign) is the two brass parts on the right side of the 3 contacts.
A little video of how it works:
      08-03-2012, 02:25 PM   #2
wonton180
wonton180's Avatar
Drives: 07 Z4MC
freaking awesome post.
I'm having a similar no start problem with my car. It's very inconsistent--and the key lock itself feels kinda loose/sloppy. the instrumentation does light up completely in the ignition position (ign), but turning to the spring loaded position to start doesn't trigger the starter motor turn the motor over. I have to start the process from the beginning again any maybe it will start. My battery is new, Autozone H6-AGM.
do you think the switch is my issue too?
where did you buy the used parts?!
      08-03-2012, 04:45 PM   #3
StigJ
StigJ's Avatar
Norway
332
Sounds like you have the same issues as I did. So get a new switch. I got mine from a company in Denmark that deals used and new parts and with wrecked BMWs.
I can also add that I have had no faults with the ignition after I changed this.
      08-04-2012, 04:14 PM   #4
elerner61
elerner61's Avatar
154
Drives: '07 Z4M Roadster
Could you post where you sourced the used parts? Always good to have a list tucked away. Thx!
      08-04-2012, 04:34 PM   #5
StigJ
StigJ's Avatar
Norway
332
www.koed.dk
      08-05-2012, 08:21 AM   #6
wonton180
wonton180's Avatar
Drives: 07 Z4MC
In the US, you can also try your local "you-pull-it" junkyards. this switch is used in the entire E46/E39 line as well so it will be easy to find in salvage yards.
p/n 61326901961
I just picked one up yesterday for $10!
      01-17-2013, 09:41 PM   #7
Brian817
Drives: Z4 M Roadster 2006
Just wanted to say, this is by far the best post I have seen. Vids, pics, step by step.. awesome! Thanks for all the help and sharing your knowledge. Great stuff. Just hope this solves my problem lol
      02-22-2013, 08:53 AM   #8
StigJ
StigJ's Avatar
Norway
332
Thank you for the kind words. Glad it could be for some help
An for info I have not had any errors with the ignition after I changed this part.
      09-02-2014, 06:42 PM   #9
jeebus87
Drives: '11 atacama yellow Z4 35i
Sorry for bumping an old post, but I just wanted to give you a huge "thank you" for this writeup. I've been having intermittent starting issues for the past couple months but could never replicate it at my indy's shop. So this week it was very persistent, engine would fire only after the 2nd or 3rd time turning the key. Took it to the dealer as they are in a very convenient location for me... diagnosed a bad starter ($170 for diagnosis) and they wanted $1300+ for the fix. No f-ing way I'm paying that much. My indy replaced the starter for $600 as I assumed the dealer knew what he was doing in placing the "bad starter" diagnosis. New starter goes in on friday, and everything seems to work fine, but then I get a couple starts this weekend where it takes 2-3 key turns to fire the engine. I start to get angry.
Fast forward through the weekend, and wouldn't ya know it, stranded in my garage on a tuesday morning when I'm supposed to go to a new clinic assignment (not cool). Engine won't fire no matter how many times I turned the key. Now I'm really pissed off. I wind up borrowing a good friend's car for the day. I get an ignition switch from the part's warehouse after letting the dealer know exactly how I felt, pop it in in 20 mins courtesy of this post, and sure enough car is working like a charm. Starts up every time like a champ. Lesson learned yet again!
      03-13-2015, 03:32 PM   #10
Reborn_
Drives: 2007 BMW Z4MC
Fantastic thread - great job with the information, pictures, and videos. Helped me diagnose my odd intermittent starting issue and made replacement a breeze!
      03-16-2015, 04:28 AM   #11
StigJ
StigJ's Avatar
Norway
332
Glad to hear that this DIY could help others too. That was what I hoped for
      03-16-2015, 05:29 AM   #12
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Great stuff here....
Threads like this is what makes Zpost such great site for all of us.
      03-16-2015, 02:58 PM   #13
Reborn_
So my problem did not go away. It goes to step 3 just fine (every time) - but the car will not try to start - starter doesn't engage. After as few as 3 attempts or as many as 20 attempts (pulling key completely out, trying again) it will finally just fire right up, no problem. This was the same issue I had prior to replacing the starter switch per this thread. Most times, the car starts fine on the first attempt.
I have 2 thoughts now - starter solenoid (if that can be replaced independently of the starter - does anyone know?) or continue working my way up the ignition system towards the key. Any input would be appreciated.
-Frustrated.
      03-17-2015, 03:09 AM   #14
StigJ
StigJ's Avatar
Norway
332
Sounds like a starter or immobilizer problem. Try your spare key.
      03-18-2015, 10:41 AM   #15
Reborn_
Thanks - I was going to go after the clutch pedal switch and battery first, when the previous owner pm'd me (he saw this thread). He recommended adjusting the clutch pedal stop that he had on there - I didn't realize that it was adjustable/aftermarket. So far so good. I had never tried listening for the click of the relay, but after adjusting that all the way down and gaining a 1/4" or so, I hear the relay click near the bottom - so I'm hoping that was the real culprit. We'll see if the problem rears its head again.
      03-19-2015, 09:28 AM   #16
elerner61
elerner61's Avatar
154
I had my clutch stop set too close to where the clutch switch would function. I would notice that on warm/hot days after running the car, when trying to restart it the starter wouldn't run unless I pressed the clutch just a little harder. I (eventually) adjusted it just a little and no more issues.
      03-30-2015, 11:20 AM   #17
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
On extremely hot days, sometimes the clutch switch isn't triggered on the first try when I push in the clutch. I push it in a bit harder the second time and it starts.
I believe there is something in the pedal/clutch stop stackup that is swelling with the heat and having the effect of a longer clutch stop. So keep that in mind when you set the clutch stop.
      10-15-2015, 12:47 AM   #18
Forbes
Daily driver/Weekend mechanic
Forbes's Avatar
Drives: '06 Z4 3.0i Roadster
2006 Z4 3.0i  [6.00]
2014 BMW 328i  [0.00]
Did it; fixed it
Before I knew about this I was sure it was the starter. I had an intermittent no crank situation with a fully charged battery.
After replacing the starter, I did a bit more research and found this post.
'06 Z4 3.0i N52 AT
This fixed it. Thanks for the DIY.
      12-31-2015, 07:08 AM   #19
Roadroach
Roadroach's Avatar
165
Drives: 2006 Z4 3.0si coupe w/stick
I had this intermittent problem for the whole week I've owned my 'new' '06. Yesterday I thought I was going to be stranded but after >20 attempts it finally caught and started right up. Did some quick research and found this thread. Found a replacement switch last night at a local autozone(!) and swapped it out last night.
Problem appears to be resolved.
THANKYOU to the OP.
And another big THANK YOU to the zpost community. You guys rock.
2006 Z4 coupe - with HOMELINK!
1966 Mustang GT fastback (too many mods to list)
2015 335i GT
2014 981 Cayman S manual
      01-06-2016, 01:56 PM   #20
drewski429
Drives: 2006 Z4 3.0si Sport 6MT
Maybe the same issue
Just ordered a new ignition switch after going crazy over this problem, hoping if fixes it. No steering wheel button function, no cruise, usually no horn, airbag light stays on, radio will randomly shut off, but stays on along with the dome light when I turn off the car and remove the key. The issue where the starter wasn't getting steady power only began to occur after weeks of the "christmas tree effect"
https://youtu.be/AbrMXIB3clg
      01-08-2016, 02:22 PM   #21
drewski429
Resolved
Ignition switch may not have been the issue, it seemed like structurally it was only wobbly if messed with, but the new one felt precise and snug, so I installed it.
Noticed a very small in line wire harness/wire tap where a black wire and a white wire come out one end and are folded and tape wrapped to the plastic harness... about 1/16th of an inch of bare wire is showing from over-stripping before crimping.
So this bundle of harness/taped wire was jammed up against the metal housing of the steering column and the ledge of plastic harness caught on a corner of said metal housing, resting the exposed wire against metal.
Control or ground wire, whichever it may be, it made all the systems controlled by the ACC/ON/Start positions of the ignition totally shorted out.
Glad it was fixed with more electrical tape, not glad the assembly plant in NC didn't use more electrical tape.
      01-08-2016, 02:55 PM   #22
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^fantasic!!
Glad you found the problem and updated us.
it will be helpful for others to chase down a similar problem.
Search this Thread:
Advanced Search
