      04-17-2014, 11:33 PM   #1
rusty_sojah
No_Country
48
Drives: 440
stock / facroty sub removal question
just a question but what is behind the stock sub box area? i want to remove the stock subs and open up holes into the trunk area. it is just particle board and carpet behind the sub compartments or metal and wires and what not... maybe even part of the fuel tank, i am not sure which is why i am asking here.
thanks for the info you guys that are smart on the z4
      04-18-2014, 08:27 AM   #2
Steeler
Steeler's Avatar
2428
From what I remember there is a plate bolted to the bulkhead behind the plastic trim that the speakers attach to.
The bulkhead is metal of course and the area behind the trim is quite shallow
Search bmw z4 rear speaker removal in images for some good shots.
      04-18-2014, 11:00 AM   #3
ssummers
Drives: 2005 Z4 3.0
It does not really open to the trunk, that area sits lower than the trunk floor.
There is a foam "box" for the sub, it pulls out, then there is the metal framework between the trunk and the sub area. If I remember there are some small access areas, but nothing large, unless you want to remove some metal that may be structural...
      04-20-2014, 04:52 PM   #4
rusty_sojah
No_Country
48
Drives: 440
well prolly won't be doing that then ^ ^ ^
thank you
      04-20-2014, 05:47 PM   #5
Shipkiller
Shipkiller's Avatar
Drives: Me
Why don't you just remove one of the grills/subs and just look. That would be your best bet.
      05-15-2014, 02:11 AM   #6
rusty_sojah
No_Country
48
Drives: 440
seriously bro ^ ^ ^
