01-16-2021, 11:38 PM | #1 |
Rep 57
Strut tower position after coilovers installed
So I’ve just install a set of coilovers at my local shop, its my first time seeing that there is play/adjustment on the tower where the coilovers connects to the frame.
attached is the photos of my strut tower, but is this normal? |
01-17-2021, 12:09 AM | #2 |
Rep 1,543
yes, it's normal.. do you know the camber/caster spec?
01-17-2021, 12:33 AM | #3 |
Rep 57
It’s currently -2.5 camber in the front, but now the left and the right is not the same.
so they use this to help adjust camber with this? or this actually adjust caster? I’m thinking of adding a strut bar, so it will affect the camber? |
01-17-2021, 09:55 AM | #5 |
10859
Rep 4,893
I don't think the slots are that much elongated? (maybe the m coupe is different?)
Maybe the shop altered the holes a little? I also see a potential crack at one of the holes.
01-18-2021, 04:58 AM | #6 |
Rep 57
Luckily I’ve purchased an OEM strut bar.
01-18-2021, 05:00 AM | #7 | |
Rep 57
That’s not a crack, its a scratch with a bit rust on it after the paint is gone.. |
