      06-30-2020, 08:18 PM   #1
maupineda
Drives: E86 Z4MC
E86 H&R Coilovers Knock -- FIXED!!!
I am super happy as I finally was able to fix a little knocking noise I had in the front suspension of my Z4MC. This noise has been there since I bought the car, and I actually changed the coils it had to H&R thinking it could be the coils and camber plates setup I had, as solid mounts inevitably result in higher NVH.
Well, I was disappointed to find that the new coils would do the same
After searching online I found that some times the problem is with the springs as the coils can slap one another, so I found that some companies like TEIN and EIBACH do coils spring sleeves and so I decided to give it a go.
I just installed those on the fronts and OMG, the noise is completely gone and it just saved me from throwing more money at this issue as I was thinking that my control arms and bushings may be wrong since everything else is new!
I kid you not, the ride now has a pliant ride over pavement joints that before were very harsh and abrupt and would create a knock, now is completely silent and feels more compliant.
When looking at the OE spring is evident why they are silent, all coils are of a different diameter, so even when the coil compresses fully the coils never touch, the lowering spring of H&R coilovers, on the other hand, have the same diameter for the top 3 coils, then reduce gradually to meet the adjustable perch. These 3 coils are almost at max compression with the vehicle on the ground so any small suspension travel make them contact and when the move is quick and sudden they slap creating the knock
Below the images of what sleeves I used and how they look installed, I used one sleeve per spring which is enough as covering the middle of the 3 top coils give cushion to the progressive part of the spring.
Sorry for the poor light, but you can see the sleeve in the next two photos
I bought 4 of these sleeves as sometimes my rear does it too so this weekend I will put them on as I need to take the wheels off and maybe even lose the shock to squeeze the sleeve on. the front went in, in seconds. It took me more time identifying where to start putting the sleeve to cover the right contact areas.
XMetal1136.00
AK72286.00
      07-01-2020, 12:46 PM   #2
No_Dominion_2
AKA No_Dominion
No_Dominion_2's Avatar
Drives: 2007 Z4M
Thanks for posting this, I just ordered a set of H&R coilovers and might as well get some of these and put them on preemptively!
Evolve CF CSL Airbox /// SGT Headers /// DKF Resonated S1 /// RPI Mufflers /// Underdrive Pulleys /// Alpha-N Tune
Mstache /// CF Side Extensions /// Skyer CF Rear Spoiler /// CF Engine Cover /// Strong-Strut Braces
H&R Coilovers /// MRR GF7 Wheels /// PS4S /// Remote Start /// Rennline Pedals
      07-01-2020, 02:53 PM   #3
maupineda
Drives: E86 Z4MC
I would 100%. My coils were new installed with all new mounts, hardware, etc, and had the issue. The issue is there by design. I don't see why wouldn't you have it. Also, even when setup to the highest setting is not enough for me. So I would advise buying the rear taller upper spring pads (10 or 15mm) and a KW perch spacer.
      07-01-2020, 03:44 PM   #4
CJW2OO4
CJW2OO4's Avatar
I bought some of these as well got a set of 4 shipped for 70 bucks. I still need to get all new bushings for the rear and front sway bar links. I'm thinking about going OEM. Anyone have any input? (I too have new yet to be installed H&r coilovers)
      07-01-2020, 03:48 PM   #5
maupineda
Drives: E86 Z4MC
I have not done anything with my bushings at the rear yet, but given how stiff our cars are, I am sure I will go with OE, but I don't track the car, nor have intentions to. is my weekend toy only.
