      08-04-2014, 06:21 AM   #1
SwissArmy
Why so serious?
SwissArmy's Avatar
Limp Mode w/ Codes [1st gear = Reverse?!]
Hey guys.
2004 BMW Z4 3.0i w/ SMG Transmission. Currently in limp mode and have the following codes. All hard coded, nothing can be cleared.
Back story: I got the SMG Pump replaced TWICE. The first time around the pump worked, no codes. But then the pump failed. Second time around, with a brand new pump again. No codes, drove for a day. The next day, INTERMITTENT limp mode. The next day, stuck in limp mode.
OFTEN, 1st gear would throw me into Reverse - SCARY when taking off on a green light
Maybe it was not flashed/re-taught properly? Alternator? Regulator? TCM? Battery?
I've had the battery tested, and replaced twice with new batteries.
IF it is the alternator/regulator, please visit my other thread: http://www.zpost.com/forums/showthread.php?p=16404539
Engine Codes
299A Error Management EGS
281D BSD Alternator Signal Implausible
281C BitData Port Signal Implausible
27C3 Thermal Oil Level Sensor
Tranny Codes
20916 (51B4)
20213 (4EF5)
I get other sensor codes like, Convertible roof top, Dashboard cluster, Heating/AC etc. But they have been cleared.
Your thoughts? Thanks
      10-10-2014, 11:28 PM   #2
rudyboy
Drives: Bmw e85,
Same situation with mine. Auto with smg.. 138,000 miles...tranny needs rebuilt...
      10-11-2014, 11:07 AM   #3
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
A bad alternator can cause all kinds of coding errors. My M thought it was an automatic, and wouldn't start because the gear selector wasn't in park
